Air leaks can cause more energy loss than a lack of insulation sometimes. Thermal Imaging can help find these air leaks so they can be repaired.
Depends are they big or small air leaks . Small air leaks can be needed some homes.
To tight a home can be a problem.
Good point Roy. There is a lot to consider before you jump into sealing off the air leaks.
