Hey guys I’m doing a 4 point on a home with aluminum wiring. The electrician updated receptacles with alumniconns but did not change out the sub panel breakers and I’m not sure if I need to call that out for the insurance company. My client is from out of state and I’m wondering if I should suggest he have more work done at the panel before I publish the report.
Did you verify that the breakers are not AL compatible?
As Jeffrey indicated, the panel’s breakers may have been updated or are/were listed as Aluminum compatible.
