This propane water heater has the shutoff about seven feet away and above a furnace duct, I believe the shutoff should be nearer to the controls and in sight…am I right,need confirmation asap thanks
I would report as being too far.(or at least report/document where it IS located)
I believe 6ft is max…per the c word.
…and check the rating on the copper line.
3 feet for the WH, 6 feet for a dryer
3/6 feet are for the connectors…code does call for valves to “immidiately” follow connectors…
7ft and out of sight, definately call it out…
…and I missed the “propane” part. Propane unlike ng does not contain sulfur.(not caustic/acidic)
therefore I’m not sure if sulfur rated copper line is an issue…
…well OK…Type L copper line for propane is required , same as ng.
Thanks guys appreciate the feedback
