Found some areas on a new construction home were the brickwork mortar wasnt exactly great. My concern would be water penetrating these areas in the winter and then possibly becoming a bigger issue. Just wanted others opinions and thoughts and was looking for some good brick informational links.
If I see this type of thing I usually make a comment about it in the exterior siding portion of my report. I do not let it make it to the summary…but it does go to the maint. summary…
Ditto what WF said…I also mention it verbally to my client if they are present.
Thats a weep hole vent, much like a plumbing vent it lets air in to the system so the weep hole drain more effectively. Also helps vent Radon gas out of the wall.
