XBYS.GuideInfo
Relocatable Power Taps
                    [View Listings](http://database.ul.com/cgi-bin/XYV/cgifind.new/LISEXT/1FRAME/srchres.html?collection=/data3/verity_collections/lisext&vdkhome=/data3/verity_sw_rev24/common&SORT_BY=textlines:asc,ccnshorttitle:asc&query=XBYS%3CIN%3ECCN+and+not+GUIDEINFO)            Page Bottom
               **Relocatable Power Taps**
Guide Information for Electrical Equipment for Use in Ordinary Locations
USE AND INSTALLATION
This category covers relocatable power taps rated 250 V ac or less,  20 A or less. They are intended for indoor use as relocatable multiple  outlet extensions of a single branch circuit to supply laboratory  equipment, home workshops, home movie lighting controls, musical  instrumentation, and to provide outlet receptacles for computers, audio  and video equipment, and other equipment.
Relocatable power taps consist of:a) One attachment plug and a single length of flexible cord  terminated in a single enclosure in which one or more receptacles may be  mounted, orb) One attachment plug and a single  length of flexible cord terminated in a single enclosure in which one  or more receptacles may be mounted. Up to six lengths of flexible cord,  not exceeding 1-1/2 ft in length, may exit the enclosure with each  length terminating in a separate, single cord connector, orc)  One attachment plug and a single length of flexible cord terminated in  an  enclosure in which one or more receptacles may be mounted. A second  enclosure in which one or more receptacles may be mounted that is  interconnected to the first enclosure with flexible cord, maximum 1-1/2  ft long, may be employed. An interconnected switch housing may also be  employed to remotely control the relocatable power tap, provided that  the length of the flexible cord between the enclosure and switch housing  is not greater than 6 ft. They may, in addition, be  provided with fuses or other supplementary overcurrent protection,  switches, suppression components and/or indicator lights in any  combination, or connections for cable, communications, telephone and/or  antenna.
Relocatable power taps are intended to be directly connected to a  permanently installed branch circuit receptacle. Relocatable power taps  are not intended to be series connected (daisy chained) to other  relocatable power taps or to extension cords.
Relocatable power taps are not intended for use at construction sites and similar locations.
Relocatable power taps are not intended to be permanently secured to  building structures, tables, work benches or similar structures, nor are  they intended to be used as a substitute for fixed wiring. The cords of  relocatable power taps are not intended to be routed through walls,  windows, ceilings, floors or similar openings.
The length of the power-supply cord, as measured from the outside  surface of the enclosure of the relocatable power tap to the plane of  the face of the attachment plug, should not exceed 25 ft (7.62 m) nor be  less than 1.5 ft (0.46 m).
Relocatable power taps have not been investigated and are not  intended for use with general patient care areas or critical patient  care areas of health care facilities as defined in Article 517 of ANSI/NFPA 70, “National Electrical Code.”
RELATED PRODUCTS
Relocatable power taps employing cord sets provided with  leakage-current detection and interruption are covered under Cord Sets  with Leakage-current Detection and Interruption (ELGN).
Portable ground-fault circuit interrupters are covered under Ground-fault Circuit Interrupters (KCXS).
ADDITIONAL INFORMATION
For additional information, see Electrical Equipment for Use in Ordinary Locations (AALZ).
REQUIREMENTS
The basic standard used to investigate products in this category is
(http://ulstandardsinfonet.ul.com/scopes/scopes.asp?fn=1363.html), “Relocatable Power Taps.”
UL MARK
The Listing Mark of Underwriters Laboratories Inc. on the product is  the only method provided by UL to identify products manufactured under  its Listing and Follow-Up Service. The Listing Mark for these products  includes the UL symbol (as illustrated in the Introduction of this  Directory) together with the word “LISTED,” a control number, and the  product name “Relocatable Power Tap,”“Power Tap” or “Outlet Strip.”
The Listing Mark for this category requires the use of a holographic label.
