Clarification on labeling
I’m new to the forum, this is my first post - so be gentle
I am going thru the Electrical Inspection course and had a question on the GFCI with old wiring.
Directly from the course
"The image above is a GFCI that was installed to replace the old, 2-prong ungrounded wall receptacle in an older home. This GFCI must be labeled as a GFCI without an equipment ground. It was not, and that’s a defect. "
My question is: What is the label supposed to look like and where is it to reside?
Any help anyone can provide is greatly appreciated.
Regards,
Garry
Image and narrative I use in my reports when I run into this. Feel free to send me a royalty check if you want to use. :wink:
Put a sticker on a receptacle with wordage that nobody understands. That makes everything safer.
Is the green check and the fire orange arrow for cover screw head orientation? :zany_face:
Thank you for the clarification
Thank you for the clarification on this
This is great, thank you for the link and the clarification
You’re welcome.
Welcome to the forum, Garry. Good luck with your studies. Ask questions when you need help.
Thanks Bert. I am sure I will ask more. There is a lot of information to digest for sure.
