dmacy
(David C. Macy, CMI)
October 31, 2006, 3:47pm
Bedroom closet had an old moisture stain & the fireplace flue had evidence of condensation. What is the cause of the condenstion.
It is a wood fireplace with a metal insert. There was an exterior vent as well and it was blocked with yellow jacket nests.
The exterior chimney for the fireplace is the metal one. Is the rust staining typical or does this indicate a potential problem?
Thanks
Dave
gbeaumont
(Gerry Beaumont)
October 31, 2006, 6:35pm
2
Hi to all,
Dave the cause of the condencation would appear to be the hot vent pipe running through a colder attic space, is the moisture stain directly below the flue?
Alternatively they could just be leaking flashings.
Regards
Gerry
dplummer
(dplummer)
November 2, 2006, 1:00am
3
I’d go with the leaking flashing. The water staining is fairly large & there appears to be a distint water line on the metal flue. Doug
