Cracked Heat Exchanger?
Originally Posted By: jsmith3
http://www.nachi.org/bbsystem/usrimages/P/P9230069.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/P/P9230068.JPG ]
Originally Posted By: jwilliams4
DO NOT CALL FOR A REPLACEMENT!!!..unless, of course you want
to pay for it. Recommend an HVAC professional and let him hang
his butt out. Protect yourself...
"not just an inspection, but an education"
Originally Posted By: jbushart
It’s always best to recommend that the furnace be serviced by a qualified technician prior to use; gas, oil or electric. If it is more than five years old, I add the recommendation that the qualfied technician also do a check for CO emissions if gas or oil.
Home Inspection Services of Missouri
www.missourihomeinspection.com
"We're NACHI. Get over it."
www.monachi.org
Originally Posted By: dandersen
Jon,
For your info only, the cracks are not the heat exchanger.
I would write it up and refer it to an HVAC contractor.
As they are, they are unlikely to be any problem at this time ( the supply air side of a heat exchanger of a furnace is in a positive pressure).
This condition does require monitoring, if nothing else.
You can not see the important parts. If there are cracks here, it is very possible that there issues with the equipment which require further evaluation.
This faceplate can be replaced.
Originally Posted By: aslimack
Document your concerns and refer it to the specialist.
Adam, A Plus
Originally Posted By: Gary Reecher
As stated the cracks are on the vestibule panel, however those cracks indicate something else may be wrong. Incorrect or inadequate venting, lack of combustion air, furnace oversized for ductwork.
There could also be cracks elsewhere and actually in the heat exchanger.
Gary Reecher, CM
HVAC Service Technician
MechAcc's Carbon Monoxide Site Links
