Dead front removal
I am preparing to achieve my Florida certification, but I am confused on the subject of deadfront panel removal. In the initial training course it is stated clearly that as inspectors we do not remove the dead front panel to look into the service panel. However, in the specific Florida training course it is being taught that we will be removing the panel to inspect the inside. I would like to have it clear for me which is the accepted practice specifically for the state of Florida.
I recommend you review the InterNACHI Code of Ethics…
Not sure if there is a more current SOP for Florida, this one is from 2013
61-30.803. Standards of Practice, Electrical Systems, 61-30. Home Inspectors, D61. Departmental, 61. Department of Business and Professional Regulation, Florida Administrative Code
Thank you for the information. I was pretty sure that it would be governed by the jurisdiction, I just wanted to be clear. It is talked about so much about what the requirements are of a home inspector and it seemed to me that a lot of the “standards” would be the same nation wide. But I like the idea of having to inspect a panel.
The SOP is your guideline for home inspections, it’s best to know all of these requirements and to include them in you PIA (Pre Inspection Agreement) so that clients will have knowledge of what is required and what is not required from your inspection.
Not all states follow the same SOP, some states have their own SOP and some say to follow NACHI SOP or ASHI or even give you a choice to follow either of these two.
Good luck moving forward!
What training course is that?
I am taking the courses to become licensed for Florida.
Not quite. The wording constantly confuses newer inspectors.
What it says is that removal is not required.
Ie, if it’s dangerous, don’t do it.
If you have to stand in a puddle of water to remove the cover, don’t.
If the panel has sparks flying out of it, don’t.
If you have what I call the most dangerous panel, don’t.
But if it’s otherwise a regular panel that you feel safe with removing, then you can (and likely should).
I train all my inspectors to safely remove the dead front cover unless it’s a dangerous situation, and old Stab-Lok, or one of these:
You are required to follow the SOP of the state you are licensed in. This supercedes any proffessional organization SOP, including InterNACHI.
^^^ This.
Florida has it’s own SOP, follow that one.
https://flrules.org/gateway/ChapterHome.asp?Chapter=61-30
IDK about Florida but in SC we have to take it off to determine if aluminum wiring was used or the type of wiring used. And once you take off the panel…everything is visible for inspection.
In my area of rural Southern Minnesota… Ray’s comment is only partially true, (referring to the “determine” part).
Opening the panel will only provide a “piece” of the puzzle. This is where experience comes into play!
It was once common practice in homes that utilized Panels with Edison Fuses (usually in Basements), that gutting the panel of all related components and converting the old box to a “Splice Box” for use when relocating the NEW Updated Breaker Panel, (usually when ‘Finishing’ the area it’s contained in). In Minnesota, it was permissible to use this Splice Box for extending New conductors from the New Panel if located within 20 feet of the New Panel.
The point being… IF you open the Panel in an older home and observe new conductors, your EXPERIENCE should ‘kick-in’ and tell you to 1) Pull a faceplate off a receptacle to check the type of conductors matching what’s in the panel, and 2) Check for a (“Hidden”) Splice Box.
Most that I have observed, were converted back in the 60’s-70’s-80s, and homeowners have become very creative in hiding the box locations, (cabinets, wallpaper, pictures, etc.).
Remember, the key to Inspecting is observing CLUES and RED FLAGS suggesting there may be an issue(s). Not everything is cut-and-dry in-your-face. You will have to ‘Dig’ for most significant defects, that usually means making access when possible.
