I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Thanks for your help!
A “constructed” swale is an exception when lot lines, walls, slopes or other physical barriers prevent 6” of fall within 10’ (sheet grading).
I guess that what I am saying is that a swale is not the slope itself, as the image suggests. The swale is created when a channel is formed between two slopes. A swale could be formed between two houses that are properly sloped, but the slope itself is not a swale. The image also suggests that properly sloped grading away from a foundation should always include a swale. The only time an engineered swale (or drain) is required is when a listed exception exists.
Yes, the slope is the grade away from the structure, the swale is the grade of the slope to the front and rear of the lot. (Typically).
A swale is a shallow ditch. Where is the ditch on the right side of Zach’s image?
Image has been updated, hit refresh.
Thank you!
I still don’t understand what IRC model code the image is meant to convey. The new image and verbiage makes it look and sound like moats are required around every structure.
Thank you!
Thank you!
I agree with Richard; the following statement is misleading.
Perhaps the first sentence should read:
“Proper drainage should divert surface runoff away from the foundation.”
Looks good. Everyone above is over-thinking it as if we are code inspectors. It communicates what a home inspection client needs to know. Its not a diagram we would demand a builder to adhere to.
Stating that proper drainage requires swales implies that the absence of swales is improper, which is factually incorrect and potentially misleading. That is not overthinking, IMO.
It really had nothing to do with code. However, code had some good expressive language.
Looks great, Zak! Thank you.
Great image, Zak. This is better than the picture I have been using. I’m going to start using this one, thanks.
Thank you!
