I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Your experience helps to make these improvements to make quality images. Thank you!
Seams are not heat welded.
Never heard of heat welding traditional rubber EPDM.
I have read that fleece backed material with EPDM in the UK can accept heat welding but not traditional rubber EPDM.
Robert has an exception which is a consideration. Modified EPDM can sometimes be welded. But typically EPDM is not thermoplastic
Thank you, Brian. You are correct.
