Drone for roof inspection
I walk all roofs that I can access but want to get a new drone roof inspections. Anyone have a recommendation?
The best one not made in China :wink:
I like the DJI Air series. It’s a nice middle ground between price and performance. I had a DJI Mavic Mini before the Air 3S. The Mini is good and comes at a great price, but suffered in wind. A sturdy breeze rendered it fairly uncontrollable. The Air 3S is stable even in strong wind.
If you want a DJI, get it while you still can.
Before you get a drone you need to get your FAA part 107 pilot certification. If you get caught without it it’s an automatic minimum $10,000 from me.
If you can’t pass the test, and it’s much more difficult than you think, then get a camera pole instead.
Just by flying a done for commercial use without a license, regardless of location, the PIC should just assume that a ticket is coming from you in the amount of $10k?
I was taught that the fines fluctuate.
I thought the test was pretty easy.
Thanks ALL! I have a DJI but it is a few years old now. Looking for something with a good zoom.
And yes, I have my Part 107. It want easy but I passed on the 1st attempt. The map section almost sunk me.
I plugged the Air 3S above. The zoom is not great. I just fly closer, lol.
I have a DJI Mini 4. I like it but it is programmed with restricted areas which it seems there are a lot around here. I haven’t figured out how to tell it that I have gotten flight permission. On the other hand, I only use it about once a month. Tuesday, I saw all I needed to see from the ladder and never needed to fly the 10/12 roof. Hopefully Chinese spies are spending a lot of time watching my flights.
DJI Drones are great but can be expensive.
You will definitely need to obtain your Part 107 license. I got mine last year, study time takes two good solid weeks.
Here are the steps to obtain a Part 107 Drone License (FAA):
  • Confirm Eligibility
    • Must be at least 16 years old
    • Able to read, speak, write, and understand English
    • Be in a physical and mental condition to safely operate a drone
  • Create an FAA Account (IACRA)
    • Go to the FAA’s IACRA system
    • Create an account and obtain an FTN (FAA Tracking Number)
    • Save the FTN, it’s required to schedule the exam
  • Study for the Part 107 Knowledge Test
    • Topics include:
      • Airspace classifications & rules
      • Weather and wind effects
      • Sectional charts (this will be the hardest section to learn)
      • FAA regulations
      • Emergency procedures
      • Drone performance & loading
    • Do not pay for any courses, instead use YouTube and the FAA study guides (Amazon)
  • Schedule the Part 107 Exam
    • Book the test at an FAA-approved testing center (PSI)
    • Exam fee: $175
    • Bring a government-issued photo ID on test day
  • Take and Pass the Knowledge Test
    • 60 multiple-choice questions
    • 2-hour time limit
    • Passing score: 70% or higher
    • Receive test results immediately after completion
  • Apply for the Remote Pilot Certificate
    • Log back into IACRA
    • Complete the Remote Pilot Certificate application
    • Electronically sign and submit the application
  • Complete TSA Security Vetting
    • TSA background check is automatically initiated after submission
    • No additional action required unless contacted
  • Receive Temporary Certificate
    • Temporary Part 107 certificate is emailed within a few days
    • Allows legal commercial drone operations
  • Receive Permanent Certificate
    • Physical card arrives by mail in 4–6 weeks
  • Maintain Your Certification
    • Complete recurrent training every 24 months
    • Recurrent training is online and free via the FAA
AI Overview
DJI, the world’s leading drone manufacturer, removed its automatic geofencing restrictions in the U.S. and globally in early 2025, replacing mandatory flight blocks with enhanced warnings, placing the responsibility on the operator to follow FAA rules, and integrating official FAA airspace data into the DJI Fly app. This change allows flights in previously restricted areas like airports, military bases, and wildfire zones, provided the operator gets authorization and follows regulations, aligning with global aviation principles that favor operator accountability.
I got mine last year, but it missed the memo. It gave me 45 seconds to check a chimney in an area it deemed restricted a few months ago.
Try getting the drone and controller in an area where you have good WIFI. Go into the controller settings and check for firmware updates for the drone and the controller. That might solve your issue. :crossed_fingers:
I started with a dji mini 2, and it does everything anyone would need for roof inspections, however I do like my Mini 4 pro with 360 collision avoidance very helpful so you don’t have to worry ‘as much’ flying into a tree at the side…. Get one with 360 collision avoidance. (I actually just receive my new DJI Mini 5 (that i will be using after my rumored, recent and or upcoming retirement for things less boring than the average cracked and broken roof tiles.)
$1000s and $1000s of dollars.
