Trying to figure out best options for future drone purchase. Primary use will be roof inspections, but also interested in IR capabilities. Would this be 1 camera does both or 2 separate cameras. Looked At Typhone H drone because of 6 prop option as more stable and safer. Also wondering about picture stability technology. Does anyone have any thoughts from personal experience.
Hello, I am Michelle. I’m new and first class is about roofs. I definitely, would love to utilize drones for roof inspections. Am I to understand I must get a drone certification? video/photo for hire? Something like that… and does InterNACHI provide such course?
A Parrot Anafi Thermal is about the cheapest you can go with IR and a camera bundle that works good. They run about 1900. The DJI Mavic enterprise is the same but better quality running at about 3k. The next 2 options is the Anafi USA its about 7 and the Autel Evo 2 enterprise is about 10k. They all have the ability to switch between thermal images and regular images. I dont have any of them but to start out with at my budget the Anafi thermal is my first choice.
I used to promote the Mavic Mini as a good inspection drone. But the last 4 inspections I needed it on, the app on my phone and the controller would not connect to the aircraft. Tried everything, killing programs, restarting phone, restarting controller, changing start-up sequence, moving locations, etc. On all 4 of these, when I tried to duplicate the issue at home, it worked fine. All DJI can tell me is to try re-installing, restarting, updating, etc. I’ve had about enough of it. Maybe the Typhoon-H would make a good replacement? Any connection issues?
I’ve had a couple times where I had to re-boot the controller because either the the drone or the camera failed to connect, but a simple re-boot fixed it and it’s only happened a few times in 5 years.
