Did an inspection where the garage had been turned into an efficiency.
Garage/house door was blocked off.
Side exterior door was main entrance.
Overhead door was removed and replaced with French doors.
French doors were blocked by the bed and not accessible.
Side door was only means of egress.
Question is, shouldn’t there be two means of egress, in case one is engulfed in fire?
</IMG>
Yes, 2 means of egress are required, but I don’t believe the egress in this case would be any more difficult than from a window with a 44" high sill. I assume the door is operable.
