electric hot water heater in the attic
Originally Posted By: pmagrone
I recently inspected a condo in the Orlando Fl area where I saw an electric hot water heater in the attic for the first time in my short inspection career. All the connections appeared proper and the tank was in good condition. Has anyone else seen this and is this a proper place for an electric hot water heater? icon_confused.gif
Originally Posted By: pdacey
Water heaters are frequently in the attic here. It is OK as long as it is installed properly. Including a drain pan under the unit with a drain line to the exterior. Also, if the water heater is the highest plumbing fixture in the house, it should have an anti-vacuum valve on the cold water supply connection. This prevents the water from being siphoned from the tank when a fixture lower than the tank is turned on.
Hope this helps.
Slainte!
Patrick Dacey
[email protected]
TREC # 6636
www.southwestinspections.com
Originally Posted By: mcyr
I agree with Patrick, that the water heater have a drain pain, for if, the element lets' go, drastic flooding would occur or could occur in the ceiling of the general area. In that area, what takes care of the temperature relief valve if it lets go? To me, I do not see the logic in placing a hot water tank in the attic. Correct me if I am wrong, but strongly believe it should be where it is readily accessible.
Marcel
In this part of the country (as well as others) we do not have basements. Square footage is expensive so many builders try not to waste any for the utilities. Many homes here have the HVAC and water heaters in the attic. Besides, where else would you rather be on an inspection when it’s 105 outside? nachi_sarcasm.gif
Slainte!
Patrick Dacey
[email protected]
TREC # 6636
Originally Posted By: jschwartz1
http://www.nachi.org/bbsystem/usrimages/D/DCP_5422.JPG ]
Jay Schwartz
Coast To Coast Home Services, Inc
www.Coasttocoasthomeservices.com
Southeast Florida NACHI Chapter - VP www.floridanachi.org
NACHI - Legislative Committee Member
MAB - Member
I guess I have a hard time to relate to water heaters in the attic!
Here in Maine it usually is not a problem other then finding that it leaks or the elements are bad. You guys seem to see the dark side of these installations. Wish you luck.
I would much prefer to see these units on the outside under the overhang or enclosed box of some sort rather than having a water unit leak or pressure relief valve let go and cause a $1,000 damage to the surrounding area.
I am just trying to think this over logically.
Have a good day.
Marcel
http://www.nachi.org/bbsystem/usrimages/D/DCP_4996.JPG ]
Gas line fittings have rust on them. Unit installed less than one year.
Jay Schwartz
MAB - Member
Thanks Jay for the picture;
Hard for me to relate to the fact that a water heater would be out there under the stars with no cover.
One would think, that even in this area, an appliance of convenience as such would have some sort of protection.
To each his own I guess.
Marcel
Marcel:
I forgot to mention the heater is rated for outdoor use. I guess they failed to think about the connections!
Jay Schwartz
MAB - Member
Jay, isn’t that always the case, the Manufacturer claims that it is designed for outdoor use, (but), anything else related to the function of this unit is up to the purchaser of the unit as may see fit. Amazing how the system works.
Have a good weekend.
Marcel
Marcel:
I plan on it.
Working right now on the Aug 12 + 13th event. Huge response already. Email sent less than 5 hours ago. This will be sold out.
Jay Schwartz
MAB - Member
enjoy
