Originally Posted By: James D Mosier This post was automatically imported from our archived forum.
Hello all,
I just recieved several tools meters and started fooling around and need some guidance.
My Grandfather's house has a 1 yr old hot water heater, I was checking for CO and found 1~2 ppm at the draft hood. No problem. The house itself was at a steady 1 ppm.
I noticed that the flue wasn't really attached to the draft hood (just sitting there) so I removed it while it was firing to check the CO of the actual flue gas. About 1 foot above the hood (due to the heat) I was getting 2~3 ppm. I really expected more.
Two questions so far:
How much heat can these meters take?
Is the reason for 2~3 ppm reading of the flue gas due to very efficient burning of a relatively new water heater or a bad meter?
