It states in NACHI SOP 2.9 Attic & Insulation
The insulation in unfinished spaces
The ventilation of attic spaces
Mechanical ventilation systems
and report on the general absence or lack of insulation in unfinished spaces.
So in following the strictest of SOP lines while in the attic I am to pay no attention to:
Trusses, rafters (or does section 2.3 cover this under structure, which would only include cutting, notching, and boring of framing members which may present a structural or safety concern)
Chimneys and other roof penetrations (or does section 2.1 cover this under vents, flashings, skylights, chimney and other roof penetrations.
General structure of roof from readily accessible panels, doors, stairs.) Would the above instead fall under the roof inspection?
In short as a bare minimum SOP inspection what do I need to look to be in compliance.
I only ask because Im working on a competitor vs competior services.
Example:
Standard inspectors perform ABC
We continue with XYZ
