2006 home. Tennessee crawl space with a new looking vapor barrier on the ground.
This apparent fungal growth is interestingly just around the outer perimeter. Moisture is around 14%. It also appears that there is no moisture barrier between the foundation and sill plate. There’s no plastic and when I look in the gaps I can see any plastic or foam.
Would lack of moisture barrier allow vapor to enter that area? Have any of you seen this before?
Looks like some water staining at the venting right there.
What is the exterior cladding?
My first thought would be moisture getting in at the floor level potentially
It was particularly along the ends of the home and the front portion not adjacent to the front porch. The rear of the home along the deck also did not show fungal growth.
Morning, Stephen.
From my understanding, a Sill Seal is a material gasket, one may refer to as a flashing, installed on ‘exterior walls’ that fill gaps between the sill plate/mudsill and a foundation wall and creates a capillary break to prevent wicking from the foundation material to wood sill plates.
The caveat; the seal is for 'above-grade sill plates/mudsills, adjacent to ‘conditioned spaces’ to minimize air leakage. Unfortunately in this example the space is not conditioned and 3/4 of the foundation is below grade.
Venting a crawlapace during the humid summer is a source of moisture and mold. As stated, so is moisture from the exposed dirt and the foundation wall within the crawlspace, plus of course bulk water that enters the crawlspace because of factors such as a poor wall drainage plain and flashing, foundation wall vents, or a foundation wall less than 6 inches above grade.
I would break it down to two likely possibilities. (both of which has been mentioned above)
It is possible the previous older vapor barrier did not extend to the foundation wall. Exposing a strip of dirt which is common. This allows moist air to rise and promoting condensation at the rim joist area, typically in the winter. See Photo.
Cladding issue allowing bulk water or air movement at the area.
Finally, I do not believe the lack of a sill gasket would have this effect on a vented crawl. There is air coming in thru the vents so most negative pressure is alleviated. You definitely would not see it directly above the vent. Just 2 more cents.
I’ll add a guess. The edge of the floor next to the exterior will be cooler due to conduction of cold from the exterior and you might have humidity in the crawlspace condensing on that cooler area creating conditions favorable for mold growth.
Would you go so far as to recommend rim joist insulation be installed? My general recommendation is about apparent fungal growth, but I think it unlikely that a pest control company will make that assessment/recommendation.
