Garage Door Auto Reverse
Originally Posted By: mpedeferri
So what I understand is that if it fails it will just stay down and not reverse? Also that the 1 1/2" of 2x4 hopefully won’t damage the door in most cases? Again, thanks for the info.
Mark
There are two tests here…one is “force testing” This is done by hand by applying force to the door with your hands as it closes. The door should reverse with only a small amount of pressure being applied
The other is the "auto reverse" test. This is done by placing a 2 x 4 flat on the ground and it should immediately reverse upon contact. Both tests are recommended by manufacturers.
Read a craftsman owners manual here: http://www.sears.com/download/own/53990e.pdf
Originally Posted By: jpeck
kmcmahon wrote:
There are two tests here...one is "force testing"
Kevin,
No, no, no.
Read through those installation instructions again.
That "force" test is just how to adjust the closing and opening force TO OVERCOME THE RESIDUAL RESISTANCE OF THE TRACK and related forces affecting the ability of the door operator to open and close the door without nuisance reversals.
The only test for safety is the auto reverse test.
As soon as you start to do the force test, I would expect you to not leave until my garage door was adjusted properly. ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Jerry Peck
South Florida
Originally Posted By: Blaine Wiley
Thank you Jerry, you beat me to it.
Originally Posted By: jmertins
I wish this would have been posted about a month ago with all these insights. I paid half the repair bill on a garage reverse mech. that “I broke”… pissed off seller…upset agent,…worried buyer…blah, blah,blah…Of course I stood my ground and fought the arguement that it was a safety test and it failed…no luck.
John Mertins
Baxter Home Inspections, Inc.
"Greatness courts failure"
Roy "Tin Cup" McAvoy
We inspect for safety and function…if it’s not functioning correctly, report.
One test is for safety, and one for function!
John,
This stuff HAS BEEN posted and discussed many times in the recent past.
It is an ongoing push-pull between those who say 'either test with the 2x4 as specified or don't test' and the 'test'em with your hand on the way down' group.
Jerry Peck
South Florida
kmcmahon wrote:
We inspect for safety and function...if it's not functioning correctly, report One test is for sagety, and one for function!
Kevin,
If the door closes and opens properly, that is function.
If the door meets excess resistance on the way down and reverses, it does not work (not functioning). If you want to adjust it and see if you can get it to function properly, then you can do your force test, then adjust the door so it is correctly set. When you are done, come over and adjust mine. ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
I have no problem with you doing a force test ... IF you are adjusting the door (do you do service work?).
HOWEVER, a force test IS NOT a safety not functionality test, the door either goes up and down properly (functionality) or it does not, and it either reverses "on contact" with the 2x4 (safety) or it does not.
Jerry Peck
South Florida
That’s sort of like saying if any water comes out of a faucet (dripping or full force) it functions…no matter what the pressuure might be. icon_wink.gif
Kevin,
The water faucet is a bad analogy.
Jerry is absolutely correct. If the door opener operates the door up and down properly, it is functional. If the door reverses on contact with the wood block, the safety is functional. The safety reverse is as much a function of the distance the door travels as the force required to reverse it. The door may reverse at your waist level, but not near the floor where it would crush a cat, dog or child.
kmcmahon wrote:
That's sort of like saying if any water comes out of a faucet (dripping or full force) it functions...no matter what the pressuure might be. ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
No, it like saying that if water comes out the shower with enough pressure to take a shower with, it functions. How much pressure (force) is needed to accomplish that does not matter, as long as it work properly.
Now, if you were the plumber and were trying to figure out WHY the shower did not put out much water, then checking the water pressure would make sense, just like if you were the garage door service person and were trying to adjust the door to not reverse on the way down.
But if the garage door goes up and down properly, and the door is balanced properly, ... testing force has nothing to do with testing functionality - you've already tested that by putting the door up and down.
Jerry Peck
South Florida
icon_lol.gif icon_lol.gif icon_lol.gif you guys are too easy icon_lol.gif icon_lol.gif icon_lol.gif
kmcmahon wrote:
![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) you guys are too easy ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif) ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Jerry Peck
South Florida
Originally Posted By: dbrown
I will never put any object under a garage door to test the reversing mechanism,simply because if the garage door device fails,the opening device could break,or cause damage to another component.However,if the garage door is equipped with an “electronic eye” device to automatically reverse the garage door,that is the only device that I will check.If it does not have "eyes"then I will check the grage door opener by trying to force the door back up while it is closing.I do not apply more than approximately 10-15 pounds to the door to test it.If it does not reverse with that much pressure,I release the door and let it close on its own.I know how the manufacturers suggest you test it,but this is the way I do it.
Originally Posted By: chorne
Hi Guys,
I am with Blaine, use a 2x4 in the center of the opening if the opener
breaks than it was ready to break.
Carla
Each of us need to decide what tests we are and are not going to do in accordance with or in excess of the SOP.
Door Access Systems Manufacturer's Association Maintenance & Testing Instructions
International Door Association Automatic Garage Door Opener and Garage Door Safety & Maintenance Guide]
Wayne Dalton Garage Door Safety
Consumer Product Safety Commission Garage Door Information
For the anal retentive among us
And for the truly anal retentive
Enjoy.
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
www.b4uclose.com
Originally Posted By: cradan
mpedeferri wrote:
So what I understand is that if it fails it will just stay down and not reverse? Also that the 1 1/2" of 2x4 hopefully won't damage the door in most cases? Again, thanks for the info.
Now that you mention it..."tested" a door about a year-and-a-half ago, on a detached 2-car. It was one of those "high quality" ![nachi_sarcasm.gif](upload://6HQh6KbNiD73gqTNQInjrR2zeJw.gif) stamped-sheet metal jobs, about 3x the thickness of a good piece of Reynolds wrap. Fairly common on newer installations in the area.
Visually examined the entire door installation, placed 2" x 4" on floor, hit operator button. Door closed (apparently smoothly), contacted 2" x 4", and failed to stop/reverse. Result? Crumpled tin-foil. LUCKILY, the client was a good friend. LUCKILY, a towel, couple of 4" x 4" sections, and a rubber mallet more-or-less returned the door to its original condition.
I understand that the arm(s) under the door "force survey" is not an approved testing/inspection methodology, but I'll NEVER place another 2" x 4" under a door (particularly a tin-foil type) WITHOUT the "arm test" first...Mom didn't raise an A. Einstein, but she raised no idiot, either.
Chris
http://www.inspect4me.com
Chicago Illinois Home Inspections
Originally Posted By: rwashington
Since everyone is tired of discussing this I thought I would put in another 2 cents worth…
Someone in an earlier post suggested trying a roll of Bounty instead of a 2x4. Well, I had to do my own taste test with my Sears Craftsman 1/2 hp.
The saftety reverse DID NOT work with the paper towels but DID work with the 2x4.
If the garage door or opener itself is damaged because of the 2x4 then better it than a small child.
My report would say that it appears that the saftey reversal feature does not work as intended. Placement of a 2x4 at center of door did not cause door to reverse upon contact; therefore recommend that a licensed garage door opener technician examine as this situation appears to present a safety hazard.
Richard W Washington
www.rwhomeinspections.com
