Webinars
Recordings
Grading and Moisture Intrusion with CPI® Britt Treece
CPI® Britt Treece will be presenting this free live InterNACHI® webinar on the topic moisture intrusion. Many inspectors work in areas where steep, noticeable grades are common. In suburban areas, tight row houses with limited setbacks are becoming more and more common. Learn about the issue these grades present and how to explain them to clients.
Length:
mediumOriginally broadcast on May 6, 2020
This is a companion discussion topic for the original entry at https://www.nachi.org/webinars/2020/grading-and-moisture-intrusion-with-cpi-britt-treece
