Heat Exchanger Question
I know there are a lot topics on this regarding inspecting heat exchangers, but I’m in the process of trying to explain to client what a heat exchanger does.
Scenario;
Inspection for a client last week. The home had the HVAC system replaced with a Trane system with a AC compressor unit and a propane fueled furnace uint with a heat exchanger. The listing states it’s a heat pump, propane unit. I’ve verified that the compressor is AC only as does the warranties the client sent me.
Based on info the seller has told the client, he’s still under the impression that a heat exchanger works the same way as a heat pump. It heats even if the propane burners are not on. Based on my research, I disagree with the seller but just trying to get my ducks in a row if need be.
I’ve already stated that the HVAC installer should clarify, just wondering on my end.
It is still a “heat pump.” But it only has the ability to move heat from indoors to outdoors, not heat from outdoors to indoors
https://earth911.com/home-garden/heat-exchangers-balancing-your-homes-heat-air-quality/#:~:text=Heat%20Exchanger%20or%20Heat%20Pump,with%20your%20existing%20heating%20system.
If you can research this and verify it as a heat pump, I will bow down and appreciate it greatly…
trane model number 4ttr4036l1000ba
It is not a heat-pump. Split cooling only.
Heat pumps use the same technology, or similar, to that found in a refrigerator units or an air conditioners. It extracts heat from a source, such as the surrounding air, geothermal energy stored in the ground, or nearby sources of water or waste heat from a factory. It then amplifies and transfers the heat to where it is needed.
Some Mini split systems heat and cool, Brian.
A split cooling system is not the same as a split heat-pump, Robert.
I would bet the exterior unit says “air conditioner” not “heat-pump” somewhere.
That would be in conjunction with an air handler if I am not mistaken.
Never heard of a HVAC system described like that.
Then you haven’t seen enough.
I ran all of that. The “L” indicates it’s an AC. The “B” in last two letters doesn’t even show up on the the Trane search.
That’s why I put “heat pump” in quotes. It is not what most people think of when we say heat pump. All the client really needs to know is that it can’t move heat from outdoors to indoors. In other words, it is not a heat source.
None of that matters. The third letter is the indicator heat-pump or split cooling. The rest is goblygook as it applies here.
Here is an example data plate
Here is another example of an actual heat-pump. Not all manufacturers are as clear, so don’t rely on this unless it says “heat-pump”. Some just say condenser with no other information so you have to go to the model #.
Ignore the red squares, I highlighted the important information.
Sorry to disagree Ryan, there is a difference between explaining how a heat pump is totally different from a heat exchanger.
Tell me your opinion on the model # I posted.
14 seer, 3 ton “air conditioner”
Heat exchanger vs heat pump - Google Search
Is a heat pump the same as a heat exchanger?
The heat pump itself consists of a compressor, which moves a refrigerant through a refrigeration cycle, and a heat exchanger, which extracts heat from the source. The heat is then passed on to a heat sink through another heat exchanger.
Heat pump or not?
