There were substantial cracks on both sides of the sump pump. A U.S. Quarter slid in quite nicely. The pump was in the front right corner of a 6000 sq. ft. home built in 1995. I could not follow the cracks outside the room in a finished basement.
There was no other cracking of any kind to be seen anywhere (foundation, walls, ceilings, floors etc.) inside or outside. Just this. I suspect this may have happened when the pump was installed. I don’t think I should recommend se evaluation. I’m interested to know what you fine gentlemen think.
Silence means we were not there .
Any advice might be dead wrong.
I would be checking inside / out with as much info as I could gather before recommendations.
I totally understand. It’s a done deal. I said it was a large crack, I could not observe where the crack terminated and I recommended further evaluation by a structural engineer and repair if needed. Awkward silence is not always a bad thing. I’ll be back:D
My personal initial gut thinks is it may be not a big concern with no other info.
Always recommend further investigation if it could be by any chance something bigger.
Not looking much at rest of thread but I see a possible water induced ripple in that drywall and would be using the meter so it is all about walking around and looking at grade,foundation,Water Intrusion stains,openings,seeing inside the pit and looking at the drains,etc.
Could just be a pipe induced cracking for all I know here.
Sorry for delayed silence. I had to go take care of some issues.
I am not sure that a SE can see any more or less than you did, based on your descriptions of the environment.
Calling an SE may be pointless, however not unwarranted.
Call the issue out as you see it. Note what you are unable to see or why you are unable to see more.
Cracks observed at the sump pump area approximate width of XX. It was undetermined at the time of inspection what caused the cracks. It was undetermined at the time of inspection if there is additional structural damage do to the fact the basement area is finished.
Seal and monitor for further expansion or damage. Advice of a SE may be sought to help provide better insight.
At 1.3 million these folks can afford to have it professionally evaluated or be prepared to live with the potential consequences. I’m convinced I did the right thing. Sleeping fine tonight:cool: thanks everyone…
