Home Inspector Kansas City
M3 Real Estate Inspection, LLC
david @m3inspect.com
www.m3inspect.com
Welcome to M3 Real Estate Inspection,LLC a Premier Home Inspection Kansas City Company.
M3 Real Estate Inspection,LLC provides greater Kansas City Home Inspection services with the knowledge and experience gained from inspecting hundreds of homes in Missouri. We help clients by informing them to the conditions of the house which may include hidden problems. M3 Real Estate Inspection,LLC is a trusted Home Inspector Kansas City Company that also provides Radon Testing and Mold Testing.
Choosing the right home inspector can be almost as important as choosing the right home. Why? Because many homes - even new ones - have defects that you may not notice. A skilled Home Inspection Professional such as M3 Real Estate Inspection, LLC has the training and experience needed to look for visual signs of defects in your new home. These defects, if not detected and repaired prior to closing, can cost you, the new homeowner, thousands of dollars in repair bills.
It is very important to know the true condition of the house, so you can determine its true value to you. I will not make the buying decision for you, but the inspection can provide you with the information needed to make the decision wisely. You will want to know: How many problems? How serious are the problems? What will it cost to correct them? and Do I absolutely need to correct the problems or can I live with them?
I strongly encourage all of my clients to be present at the inspection. You should feel free to ask me any questions you may have during the inspection process. I will point out problems and explain them to you. I will also show you the good points of the house as well. Plus, I will explain what routine maintenance is needed to keep the house in top condition. This will help you to get the most benefit from the inspection and gain the most understanding of the systems that make up your home, and how to maintain them.
Inspection services offered:
• Mechanical & Structural
• Environmental Testing
• Radon Testing
• Mold Testing
• Listing Inspections
• New Construction Inspections
• Home Maintenance Inspections
• Commercial Inspections
• Flexible Scheduling
