Horizontal cracks at basement wall
I had posted a thread about foundation cracks in the past and I know some said anytime horizontal cracks are found it should be taken seriously.
I found these on a 70’s home yesterday. Larger than hairline…less than .25 inch
goes about 6 feet total.
No signs of bowing. Also should be noted that the slope outside this area was heavily towards the home (which is common here at uphill side) and we get a lot of rain…but zero signs of efflorescence or mold or moisture coming through the wall anywhere
My verbage was going to be something like horizontal cracks indicating movement that are small and localized to one spot of the foundation. No signs of bowing. etc. However we are not structural engineers and are not the final word on foundation cracks.
A couple of things.
First, CMU walls have tremendous vertical strength similar to concrete, but much less resistance to lateral pressure than concrete foundations. It does not take much to pop a mortar joint as you show in your photos.
Second, I presume that you don’t know when the wall was painted, but that looks pretty clean and white. That makes me wonder if that wall has been painted in the last five or so years. That elevates my concerns for the cracks as they appear more recent. If I had reason to believe those cracks were thirty to forty years old, I would note them and move on. If I have reason to believe they are within the last 5-8 years, then I am going to recommend evaluation by a structural engineer.
I agree with @lhenderson2 in that the walls look clean as if recently painted. For me, the cracks whether new or old would be a concern and something I would write up.
Horizontal cracks were viewed in the foundation wall at XX location. Have a qualified Foundation contractor make corrections as needed.
You can recommend an SE for further evaluation, but most reputable foundation contractors have SEs that work with or for them, and many of these types of issues have standard repairs.
I agree with Kevin and Lon, or Lon and Kevin, and will add; recommend the uphill side of the lot facing the home’s foundation be further assessed, and improved, by a licensed landscaping soil water management company to insure water flows away from the foundation on all sides.
Horizontal cracks suggest inward soil pressure on the foundation, as already noted above. This is an important issue, so don’t downplay it as “located in small area”. At the height your fingers show, that probably is inward pressure due to freezing ground and soil/water expansion in cold weather. If not addressed, it will get worse. Let your buyer know now is the time to address it, before it gets worse. I’d refer this to a masonry and excavation contractor for further evaluation and repair. IMO, this is not a SE referral item. Adding a 4 foot skirt of 2 inch foam laid horizontally around the foundation is one way to control freezing soil penetration and control inward soil pressure at the top of the block stack. Your excavator or masonry contractor should know about this method of frost penetration remediation.
The outside negative slope you mention is important. Include having an excavator evaluate and address groundwater movement towards the foundation. A swale or French drain is a typical solution.
If gutters/downspouts are missing, that’s another important item in your narrations.
I greatly appreciate everyones input on this. I’ll adjust my verbage to help the client understand potential risks, and to protect myself as well
I was not as concerned as it didnt appear mortar had been touched up and that if a level were put on the wall there it appears it would show it level/plumb.
But I suspected I could be missing something…
thank you
What you’re showing is very very common in my area. I’d say 90% of the block homes I have inspected have that exact same crack, just below ground level.
Some of the walls are worse than others, and show major inward bowing, some slight bowing with a minor crack. Often the crack has been there for decades. Some require little attention and monitoring, some need reinforcement by a foundation contractor. Report accordingly.
Very, very common in my area as well.
Address any issues with gutters and drainage first. Get as much of the moisture away from the foundation as possible. The pictured crack should be taken seriously, but it probably isn’t a candidate for any repairs at this point. As much as we try to avoid “monitor,” this is one of those cases where monitoring is the likely best path at this point. With these types of small horizontal cracks, it’s important to let your client know that you CANNOT predict the future.
So… did you inspect the wall closely at the “ends” of the cracking, and further along the same plane for inconsistencies?
It is common for Homeowner Harry to ‘Caulk’ over any cracking, followed up with the fresh coat of DRYLOK or KILZ paint to hide the bandaid!
I sometimes work for realtors fixing defects, if you’re a builder and know what home inspectors are looking for it’s easy to hide defects from inspectors, :shushing_face:
Morning once again, Matt.
Some great posts.
Jeffrey and Scott are excelants points.
Once I see paint on poured concrete or CMU foundation walls I get offensive with my visual assessment, looking for patterns, blistering, dotting, and them unpack the specialized tools I have in my tool boxes. 1: Moisture meters. 2: Hygrometer. 3: Rubber 4 pound mallet.
Question: Why do you think paint is used in empty upper attics spaces? To hide fire damage. Hiding Damage Being The Point. Fresh paint patches anywhere. Dig deeper.
A-2: I measure ambient RH, Relative Humidity. I do that Outside and Inside on every level anyway.
The inspectors handheld hygrometer is used to measure the amount of water vapor in the air/humidity. Also to correlate dew point. Absolute humidity. When the dew point is close to the air temperature, relative humidity is high.
B-1: Electromagnetic wave propagation pinlessless Moisture meters. Quickly/easily measuring moisture content in CMU.
C-3: Tap sound test for hollow sounds.
Gently tap the surface with my rubber mallet. Listening for distinct hollow, dull, or resonant sounds. Indications: Void or delamination behind the finish.
I want to hear: Clear high-pitched and firm sounds. No thuds.
Do not rely on following cracks in paint please. The paint is most likely a flexible skin. The skin separates/cracks at its weakest point.
Best of luck.
We all want to flush out how big of a deal this is.
Report what you see. What you can’t see. Your concerns. Make a recommendation.
Negative slope. Horizontal cracking. Observed conditions may promote further cracking or settlement. Recommend foundation contractor.
Horizontal cracks in a CMU foundation wall are not good. They are usually a Red Flag of hydrostatic pressure. They do not get better, and in our company, we automatically punt to a structural engineer for further information and details on what, if anything, needs to be done.
Yes, pretty common here as well with our rain levels in western NC and our expansive clay soil.
I looked very carefully for any bowing and for any signs of repair. I can usually tell when mortar has been repointed and then painted over…same with efllorescence painted over after repair….
this was a partially finished basement and I’m betting they just wanted it to look nice with paint. But who knows….
Yes, I’ve also found foundation cracks to be unpredictable, and have seen structural engineers struggle with their diagnosis.
Future is impossible to know.
I should not have waited so long to re up my membership here and get back on the forums….Invaluable info in here
thank you everyone
absolutely
thanks!
any suggestions on moisture meters? I’ve had some that seemed inconsistent…and kept giving up on them.
Getting a rubber mallet for my kit…great suggestions…thank you!
Morning again, Matt.
Inconsistencies can be false positives to the wrong material settings.
Suggestions. The greater the Brand Name the better the accuracy and recognition. Tramex/Delmhorst/General Tools/Protimeter.
My first moisture meter was General Tools.
General Tools MMD7NP Moisture Meter, Pinless, Digital LCD with Tricolor Bar Graph. Under $100.00 dollars.
Learning how to use a moisture meter takes time and practice.
Taking good measures during an inspection takes time and practice and can be done with relatively inexpensive equipment.
I learned the square grid pattern. Every so many inches to 12" inches or 1’ foot across. Equal spacing up and down vertically on a chosen material substrate. Wood. Drywall. Concrete.
How to use a moisture meter
I have been using this for 10 years.
And on our remodels we leave a few obvious things for inspectors to find. :upside_down_face:
