system
(system)
October 26, 2005, 12:00am
Originally Posted By: wdecker This post was automatically imported from our archived forum.
Inspected an older house the other day. It has hot water heating with old cast iron radiator.
Someone had redone about half the heat piping with copper and connected the copper pipe to the old pipe (galvanized, black? Painted so I don't know).
will this cause a problem with galvanic corrosion, like in supply water piping?
Thanks;
-- Will Decker
Decker Home Services
Skokie, IL 60076
wjd@DeckerHomeServices.com
system
(system)
2
No different than your plumbing standards. Dissimilar metals will create electrolysis and promote corrosion.
Dielectric fittings should be used between dissimilar metals.
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
system
(system)
3
Originally Posted By: bsumpter This post was automatically imported from our archived forum.
Morning Mr. Decker,
I would think that this should be equipped with a dielectric union just as in a supply system, but I cannot find anything in any of my reference material...
But remember to look at the bleed valve on the radiator!
-- "In the fields of observation, chance favors only the mind that is prepared"
Louis Pasteur
system
(system)
4
Thanks, guys. I thought so. The installation was very well done and I kind of doubted myself. Thanks for the backup.
BTW: DON'T call me Mr. Decker. Makes me feel old.
Thanks again.
-- Will Decker
Skokie, IL 60076
system
(system)
5
Ok…sorry, old habits die hard
– “In the fields of observation, chance favors only the mind that is prepared”
Louis Pasteur
system
(system)
6
Originally Posted By: mthomas2 This post was automatically imported from our archived forum.
This discussion won?t settle the question, but it does give some insight into possible reasons the contractor did not install dielectric unions:
http://www.eng-tips.com/viewthread.cfm?qid=43822&page=1
