How to Perform Residential Electrical Inspections
when installing a receptacle in the bathroom the insperctor and the installer most make sure that the receptacle is gfci becaus it can disconect and prevent shocks or fires it also need to have the right wirerring and make shur that all cables are connected
Safety precautions to be taken at every stage should be documented in the form of Dos and Donts. Warning signs must be displayed. Entry should be regulated. Personnel involved must be trained in electrical safety. Safety inspection must be carried out periodically. Indian electricity rules and Acts (1945) have clauses formulated and enforced to ensure safety of every user of electrical equipment. This act and relevant rules impose several safety requirements as electricity supply undertakings/ manufacturers/ contractors/ and users… [tags: accident, hazards, guide, consequences]
During a recent inspection conducted on a commercial property inspection two items were noted to be a code violation and not in the best standard practice of the industry. The first is an emergency lighting fixture connected with a cord and plug connection. The NEC requires all emergency egress lighting to be hard wired so it can not be readily disconnected from it’s primary power source. The second item is that a fan was installed over an exit sign, obstructing the view. Exit signs are considered to be life safety systems and while it is not a serious issue it is not in the best practices of the industry.
Electricity is a part of our lives. However, it has the potential to cause great harm or death. Electrical systems will function indefinitely. Properly installed and not overloaded or physically abused can last many years. Electrical fires in our homes claim the lives of 485 Americans each year and injure 2,305 more. Some of these fires are caused by electrical defects, but many more a incorrectly installed wiring, and overloaded circuits and extension cords.
In this photo two prong outlets are in use. Two prong outlets are outdated and not properly grounded. An adapter is needed to use a grounded three prong plug which is usually improper due the the ground on the adapter not being properly hooked up.
I read an article about advertising yourself as a code certified inspector. It is not advisable to label yourself as code certified because codes can vary drastically in different jurisdictions. Inspectors have lost law suits in the past due to mis representing the property as code compliant when it was not so.
Main Electrical panel appears to be in good working condition. The wire coming into the panel is in good condition. The ledger is missing some of thee breaker identifications and the exterior cover has two screws missing. Recommend have a licensed electrician evaluate to install the proper screws and complete the ledger.
Electrical Service Panels-Although I was very aware of the problems with Federal Pacific Electric service panels. The article helped me understand all the other brands related to FPE that I should make note of. These pose a huge safety problem and the client needs to be aware of those issues. Names such as Federal Electric, Federal Pacific Electric, Federal NOARC, Federal Pioneer, FPE, FPE-Stab-Lok, Stab-Lok. In addition the Zinsco brand with blue and silver labels inside the door. I recommended a licensed electrician to evaluate any and all of these.
The electrical distribution panel of the home which was located in the garage contained AFCI breakers which protect against fires in wall cavities from arc faults on the circuits serving bedrooms. The test button should be periodically pressed for functionality.
Knob and tube wiring is an antiquated branch circuit wiring method used in the 1920s and 30s which consists of bare wiring with exposed ceramic insulators and tubes through joists, rafters, etc. This type of wiring system is a fire hazard.
this is a picture of the electric panel box in my manufactured home. this panel is rated at a 200 amp service. there are no signs of arcing or moisture and there is no missing knockouts. the legend is pretty well filled out explaining which breaker goes to which circuit but one breaker is not labeled.
electric panel boxes- before inspecting a panel box , inspect your surroundings first. make sure there are no signs of moisture or rust on or around the box. listen for sounds of arcing before touching a panel box. use a voltage ticker to make sure the box is safe to touch. any signs of serious defects advise your client to have it inspected by a qualified electrician.
IN this inspection the lack of G.F.C.I. Ground fault circuit interrupters was observed. ground fault is require in all wet locations including bathrooms, kitchens, garages and outdoors. It should be recommended that a qualified, licensed electrical contractor evaluate the issue and make appropriate changes.
Electrical Inspector. While inspecting the main service panel, the Inspector wants to first evaluate the condition of the enclosure exterior and determine his comfort in further inspection. The inspector needs to record the service amp capacity and whether the branch circuits are marked and identify any over heating, or arcing signs that may be visible before proceeding.
GFCI outlets:
GFCI outlets are required in places like bathrooms and kitchens where water is present. These outlets are constantly monitoring the flow of electricity. When detecting current flowing through and unsteady path such as water or a person it will shut off the power.
The outlet by the sink in the Master Bath was tested using the button on the front and functioned properly, however, the lights at the sink also went off when the gfci was tripped indicating improper wiring, so we recommend having the bath circuit repaired by a licensed electrician.
A type of GFCI protection was first used in South African mines in 1955. Since that time the technology has improved and they have been increasingly required because of their ability to protect people from the threat of death or serious injury from electric shock.
This electric panel is overloaded with too many wires. With the use of multiple conductors going into one breaker could cause overheating and lead to a fire. Home inspectors should recommend a licensed electrician to further inspect an electric panel with discrepancies.
Lead Facts:
Lead exposure is harmful for children, babies and unborn babies. A lot of times lead based paint if in good condition is not harmful. It is harmful however to inhale the dust or digest paint chips. Many homes and buildings built before 1978 may contain lead paint and should be properly inspected.
AFCIs or arc fault circuit interruptors are recepticals or outlets that are specially designed to detect and stop dangerous electrical arcs in homes and buildings wiring systems. Home inspectors should test all AFCIs with an AFCI tester to make sure they are functioning properly.
