Induced air and exhaust in same Pipe?
Originally Posted By: cmccann
During an inspection today I saw for the first time a 90% forced air furnace using one pipe for both exhaust and induced air. Looked through code check briefly, but couldn’t find the proper reference. The unit was installed 2003 with city inspectors final sticker, is this correct? If so how can this be possible?
[ Image: http://www.nachi.org/bbsystem/usrimages/D/DSC02695.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/D/DSC02696.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/D/DSC02694.JPG ]
NACHI MAB!
Originally Posted By: cbuell
where they exit through the roof, it changes to a pipe inside of a pipe----actually pretty cool idea----one roof penetration
Charles, wouldn’t you be drawing in exhaust air for combustion air? Is that a problem? I guess only if a heat exchanger has failed, not sure. icon_confused.gif
If this is such a good idea, why haven't I seen it done when it goes through a wall to the exterior?
Where Oh where are my HVAC guys?
NACHI MAB!
Originally Posted By: Lee Hammerstein
Technically it is not one pipe for exhaust vent and intake. There are two pipes at the “Y” fitting. The outer is the intake and the inner is the exhaust vent. It continues to the termination as a two pipe system. It requires a special fitting and a special termination. It also can be used horizontally to vent through a side wall.
Originally Posted By: rcloyd
Chuck,
It is called a concentric pipe system. As mentioned in earlier posts, at the Y it splits into two pipes (on the interior) this allows for only one penetration through the roof or wall. Less holes in the building envelope is a good thing. these systems should be installed in accordance with local codes and the manufacturer's instructions.
Regards,
Russell G. Cloyd
Intra-Spec Home Inspections
& Code Consulting, LLC
859-586-4591
www.intra-spechomeinspections.com
First time I’ve seen this system. All of the others have been the 2 pipe system going through a wall. Thanks for the info, icon_lol.gif
NACHI MAB!
