"Inspecting Tile Roofs" online video course
At the south slope of the roof several areas of scuffing appear to have been caused by a previously installed solar pool heating system. Holes in the roof material left from the anchors used to secure the solar panels were patched with dabs of mastic. The application of the mastic was done poorly and may cause the roof to leak. We suggest the roof be inspected by a qualified roofing contractor and suggested repairs be made as soon as possible.
Wind mitigation is a construction practice that may help a home to stay water tight during a major wind event such as a hurricane. Ensuring that roof framing is securely attached to walls, and roof decking is securely attached to roof framing, are just a couple of ways to provide wind mitigation. Homeowners insurance companies may provide large discounts if a home has proper wind mitigation measures installed.
The roof tiles on the front side of the home have been damaged. Several of the tiles are cracked and are in need of repair. The tiles protect the underpayment. This is considered a defect. Recommend a license tile roofing contractor further evaluate.
Installation of a tile roof should only be done by a qualified licensed roofing contractor. The installer must understand the principle of headlap to help prevent moisture intrusion. If the roof has a high pitch then battens must be used.
This is an image of a 2:12 patio roof joined to the main structure. Upon inspection,I observed that their was no base flashing or counter flashing. As a matter of fact,their was no flashing at all. Also,I observed vegetation growing from underneath the metal roofing panels. After inspecting this roof I would recommend having it evaluated by a professional roofing contractor.
When considering the purchase of a foreclosed property, never allow yourself to be persuaded to forego a home inspection. There could exist multitudes of issues in need of repair within the home that the buyer needs to take into consideration as to whether or not they want to proceed with the purchase. Previous homeowners have been known to intentionally inflict damage to the property out of retaliation.
This is a photo from the Nachi course book. This photo show wood roofing tile being installed. It is important to match the slope of the tile being installed to the slope of the roof for proper water run off.
There are many different types of tile styles used throughout the country for roofing cover. No matter what weather or climate they are used in they all serve the same purpose. Proper fastening and underlayment need to also be considered when using tile shingles.
When inspecting roofs we look for the most common items. These being broken tiles, blocked drainage flashing channels and other flashing issues. We do not walk the tile roofs as most do not need that deep of a roof inspection. This section has given me more items to pay attention to.
The roof inspection in our climate which is the hot desert is not as difficult as the more rainy of windy areas. We do find that there are tiles that are moved from there location. I suspected wind but this helps me to confirm. good info.
Concrete tiles are attractive, strong and economical. They are machine-made and provide a very clean and orderly appearance. Most of the higher quality concrete tiles have the same color all the way through the tile, which helps prevent the tile from fading over the years.
This is a picture of a hand formed clay tile roof. The roof appears to be in good condition. There is a bird stop present that appears to have been made from mortar by the tile installer. Mortar appears adequate and in good condition.
Good morning,
Ready for new school day!
JQ
tile roof has orgnic material present. The tile appears to be in good shape and functional. Interlocking poetion of tile seems to be secure. No additional roof inspection by a professional is required at this time. The tile material is clay.
The tile roof has organic material present. The tile appears to be in good shape and functional. Interlocking poetion of tile seems to be secure. No additional roof inspection by a professional is required at this time. The tile material is clay.
This photo depicts what appears to be clay roof tile. This is a low profile tile. There are several defect issues with this tile. The major defect is severe spalling. There is also biological growth and what appears to be adhesive cracking and separation.
The article read was,Termite Control in the Home. Subterranean Termites are the most damaging insects of wood. One of the first igns you may see is swarming insects. Other indicators may be, sawdust like droppings, dirt or mud tube trails, damaged wood members.
When inspecting a clay tile roof your best practice is to inspect from the ladder or the edge of the roof. It is evident in this picture that this roof already has damaged tiles. The flashing around the edges appear to have come up in this area. I would refer this to a contractor.
Date: Tuesday, May 1, 2018
Address: 123 Fake Street Raleigh NC
Tile Roof Inspection
Upon inspection of the tile roof at 123 Fake street I noticed proper flashing along vertical walls. I further noticed the installers used proper care around roof stacks. The install is a good one.
The article I found interesting is titled “Choosing Your Domain Name”. Not traditionally a marketing person and not one who has been educated in running and operating a business, I find this information helpful. The practical, down to earth information is very useful.
