Originally Posted By: Craig Shap This post was automatically imported from our archived forum.
I seem to remember reading that if insulation that is disclored possibly due to dust deposits then there is are circulating inside the attic.
This particular attic is vented with 1 gable powered vent, ridge vent and soffit venting. The pink Batts of insultaion on the knee and interior walls are darkend in color... I am not sure if this is a concern for inadequate ventilation or not?
Originally Posted By: Guest This post was automatically imported from our archived forum.
Exfiltration of moisture laden interior air frequently leaves the tell tale accumulation of dust in your photo. If the space isn’t properly vented, call the venting problem and be proud of yourself for recognizing the symptom. Good call.
Chad - This is a new problem to me - Pardon my inexperiene on reporting - I am calling it out and glad to have recognized such a problem, but How, what would you recommend as a solution to the problem?
Originally Posted By: ekartal This post was automatically imported from our archived forum.
Saw this the other day. Attic floor insulation almost black from moist, dirty air. Other tell tale signs such as rusted nail tips thru the sheathing, insulation covering soffits vents and small roof vents (older home) were all there too. Besides addressing the ventilation problem, I always report that the insulation needs to be replaced if in fact it is wet.
Craig,
Blaine already said it... 1 square foot for each 150 feet square feet of floor space. Don't mix gable vents with soffit to ridge vents. One or the other.
Craig,
I usually suggest to clients to clear the soffit vent area and add extra roof ventilation. Depending on the situation I may reccommend ridge ventilation if there are no gables, t-stat controlled fans.
The fan probably would contribute by keeping dust airborne, but the shadow lines near the edges of the insulation near the studs indicate that air is moving past the insulation into the stud cavity or through the wall. Unfaced fiberglass isn’t a good air barrier and trying to fit it well into cavities to the studs takes time. The installer of those batts didn’t "fluff’ the edges leaving them compressed. Air is leaking there and that’s why the edges are darker.
