If the closet is used as a return understand the furnace posted is high efficency with combustion air from the exterior. But with the gas lines in the closet I write them up every time is it going to be changed probally not in my area but at least its in the report. Class B vents would not be allowed either I write them up also:D
I was hoping you would say that.
Hope you realize that an argument would be that gas pipe is not designed to leak.
Just out of curiosity what language do you use to describe a gas pipe in a vent as being an issue ?
You mean like this one right next to the burner that someone forgot to tighten?
No, the gas valve was not closed at the time of testing!
I almost became “Newsworthy”!
I don’t know of Any piping water gas or other wise that is designed to leak but they all do at some point.
I don’t sugar coat my statements when it comes to gas piping in a return air. **I say gas piping not allowed to be installed in the return air replace as necessary. **And if it was supply air duct same thing:D
