Originally Posted By: Bob Curry This post was automatically imported from our archived forum.
When a high efficiency furnace is installed in an ‘air tight’ closet shouldn’t there be an air source provided to allow gas to escape if leak occurs (occurs similar to the old style upper vent for combustion air)?
Originally Posted By: phinsperger This post was automatically imported from our archived forum.
If there were a vent to allow the gas to escape (in case of a breach) it would have to vent to the outside. The total efficiency (including off cycle losses) would be lowered. If your concerned about it, It would be better to just install a gas alarm than a vent.
Thanks for the response to my question. I think that I am either misunderstanding the answers or didn?t phrase the question properly. The gas that I am referring to is not the products of combustion generated during the operation of the furnace, it is the ?natural gas ?supplied as the fuel to a gas burning, forced air, high efficiency furnace. The source of a leak could be at the valves or supply connections, etc., does that make a difference? My concern is that if a leak occurred that gas would be trapped inside the closet due to it’s air tight characteristics.
