Light switch reach from a stairway landing
I can’t seem to find a measurement or notation about this anywhere.
There is a light switch located two steps inside the staircase from the top landing. To reach it you have to step down at least one stair and maybe two or lean out over the stairs. The switch is on the opposite wall from the railing (don’t think that matters to much but there it is.) There may be an issue with the height of the switch from the stair directly below it.
If there are more than 6 risers, there should be a 3way switch at each floor level. Stepping down two stairs,IMO, does not constitute at a floor level. Personally, I wouldn’t make a big deal about it, but I would definitely advise the client of the potential hazard. For a skilled electrician, it could be fairly easy to extend the switch up between the two doors with minimal invasiveness.
I concur. A floor level. Steps have there own levels and are not considered landings.
Verbiage. A wall switch to be installed at each floor or landing level, to control the lighting, allowing a person to turn on lights from both the top and bottom of the stairs.
A Landing refers to building regulations for stair and door landings. A landing must be ‘as wide as the stairway it serves’, have a minimum depth of 36 inches (or more for certain stairways), and be kept clear of obstructions.
It’s been 15+ years (so maybe things have changed?) but I was in a CE class and an electrician talked about this and the code is/was pretty vague. Switch location just has terms like “near” or “close by”. I’ve noticed the same or similar things numerous times and it’s just not a hill I’m willing to die on. Seems like I’ve had it come up more at the bottom of stairs, like a formal set that fans out well past the wall. It often surprises me how far away and inconveniently located the switch for stairs can be, too - like half way down a hall not really even on the most common path to/from the stairs.
This one of my common rants/talking points….. Some electrician’s assistant wanders into work Monday morning with a hangover fresh off a fight with his wife and throws outlet and switch boxes where he sees fit, and we’re all stuck living with his decisions for the next 100 years. PITA? totally….. but kind of a first-world problem in the end.
I agree the switch should be reachable from the floor level. 3-way switches are typically used but are not required. A switch at each floor level or landing to control a light is required.
210.70(A)(2) Additional Locations.
Additional lighting outlets shall be installed in accordance with the following:
(1) At least one lighting outlet controlled by a listed wall-mounted control device shall be installed in hallways, stairways, attached garages, and detached garages with electric power.
(2) For dwelling units, attached garages, and detached garages with electric power, at least one lighting outlet controlled by a listed wall-mounted control device shall be installed to provide illumination on the exterior side of outdoor entrances or exits with grade-level access. A vehicle door in a garage shall not be considered as an outdoor entrance or exit.
(3) Where one or more lighting outlet(s) are installed for interior stairways, there shall be a listed wall-mounted control device at each floor level and landing level that includes an entryway to control the lighting outlet(s) where the stairway between floor levels has six risers or more.
You are correct sir as there could be two separate fixtures, each controlled by a single pole switch, one at the top of the stairs and one at the bottom.
This looks like an entrance to a basement, possibly older construction prior to the requirement.
I see this occasionally in townhouses and it usually controls the basement lighting (to turn on or off as you enter or exit the basement). You haven’t indicated what lighting it controls? Hopefully your stairwell has a railing (unseen wall). A little awkward but unlikely to be corrected.
Good place for one of these! :rofl:
If you think it’s a potential safety hazard, then by all means write it up.
If it’s the basement stairwell light switch, I wouldn’t write it up.
Step in, grab the handrail, flip the switch. I’m ok with that.
I agree with Brian. It is not in an ideal location, but it is still compliant with building codes.
I agree too. Not something worth mentioning since it’s a judgement call and the original electrical inspector didn’t find an issue with it.
Which also resolves the question regarding the concern of ‘unsafe’ position. If one grabs the handrail, one must let go to reach above it to hit the switch, or turn your body to reach with the other hand, thus an even greater unsafe condition (in the dark)!
Most of us have two hands and arms. I can easily touch / grasp both sides of the average stairwell (typically a little less than 3 feet). If the light is on on the landing above it isn’t dark. Can’t imagine the scenario you presented.
It looks fine from Ohio….
Sounds like a personal problem.
Not a problem!
Hmmmm, can you get sued for not writing it up? That’s the first question that comes to mind when I encounter these things. Me personally, I’d say it’s not accessible from the floor level which could present a fall hazard.
You “can” get sued for not writing up a defect on the neighbor’s house so that’s not a great bar to use. In a related story, many would argue that’s the bar that’s ruining this industry and making us all look like scared fools.
Morning, Robert. Hope to find you well.
Do you have any more images of the stairwell into the basement?
No visible handrail to the top of the stairs.
Personally I can not see how leaning around the door frame while on the landing will be safe for everyone. What about children, the elderly, feeble or physically mobile but somewhat infermed.
