What is the proper name for these units? I usually just call them in wall HVAC. It is in a condo and heats and cools. Also, I was not able to remove the cover because I did not have the tool required, Allen wrench I believe. Are these units gas or electric, or can’t tell unless the cover is removed?
That’s a simple air handler for either an electric heat pump or a rooftop heating/cooling unit. I always manage to get these covers off for the inspection. Also, the dating is inside.
I see these units in Condos all the time.
If it’s a heat pump, make sure you access the Condenser on the roof or outside somewhere.
Mike it ius a blower unit with thermostatic control for the hot water boiler pipe and cold pipe from chiller unit on the roof.
No dehumidification
Check for clean filter and dirty blower.(Maintenance changes them twice a year)
Notate if it is a 2 pipe or 4 pipe ambient system.
4 pipe allows hot and cold on the same day at different units.
2 pipe and the association decides (usually Late May) switchover)
I have some good canned comments for your boiler plate if you ask.
I did not have an allen wrench to get the cover off. Bob, I did run the unit and it cooled nicely, but no heat. Was it no heat because it was 90 degrees outside or because the unit was switched over?
No access to the roof. No one at the building who could give me access. I told the client I can come back and check the roof and unit at no charge if they can arrange access.
Bob, your private message box is full. You have to empty it so you can receive more messages. I am using your HappyClient template for this report.
I inspected a condo in Lincoln Park last week that had 3 wall units. You will see all kinds of systems depending on when the building was constructed and if it has been renovated.
Spoke with you but will repeat hear.
Yeah could be switched and yes get different size multiscrewdriver with various bits.
Use regular email when in doubt.To much of a pain to keep emptying the tiny box we get.
LOL, one click can select all, another delete all.
I’m just jealous that you get you rPMs filled up regularly.
You must be very popular. :mrgreen:
Nah I just hate to delete the old ones so I can remember all my enemies.:twisted:
Bob, it can’t be that difficult to remember your enemies!!!:mrgreen:
Just need to remember how many i meet .![]()
The ones you do not know about, are the ones that worry you.
Bob, you are too funny sometimes:D
If we are going to name the unit, I think we should name it Bob. Bob is a nice name. Or Bill. That’s a good one too. Maybe Joe.
Oh, maybe its a girl. If so maybe Bobbie would be better. Or Jackie, Yea! thats it. Let’s name it Jackie!
