I called this out. Natural gas vent pipe appears to pitch down as it enters the chimney. Am I being too picky?
Good call.
No you’re not. It’s a negative slope.
Also… “generally speaking”… natural draft venting should have a 12 inch vertical rise before the first elbow.
https://inspectapedia.com/plumbing/Gas-Water-Heater-Venting-Codes.php#ManufactCode
Given all the repairs to the chimney from prior vents, I think it’s time to go power assisted out the sidewall!
No, you did well to call that out, William. ![]()
William, I carried a magnetic torpedo level with me. The are small and inexpensive.
You can see them here.
You may enjoy having one with you.
