Originally Posted By: phinsperger This post was automatically imported from our archived forum.
Dave,
Some furnaces have the intake as an option to take combustion air from inside the dwelling or to run a pipe to the out side for a complete closed combustion system. A closed combustion system is a bit more efficient and in my opinion should be done whenever possible. Where the option has been documented by the manufacture it will also indicate what conditions must be met inorder to install it that way. Providing conditions are met, it is up to the installer to determine which way to install it.
Originally Posted By: dspencer This post was automatically imported from our archived forum.
A 90 plus burns it gas and blows it threw the heat exchanger which in return continues threw what looks like a radiator; which uses the return air longer and cooling it which in result return the heat to the home and the exhaust is now cool enough to exhaust in PVC out the side of the home. A air intake is not required but make the furnace more effiencent when it is used.
Hope this in short explains
