Properly looking at the job / task at hand can prevent many job site injuries. It is the responsibility of all to be informed and test equipment daily and to tag out any equipment not functioning and report this to a supervisor immediately.
During the replacement of these shingles the proper precautions for falls was taken. Safety harnesses and tie offs were used along with proper working platforms to keep from sliding off the roof. All equipment was in good working order and all safety equipment was in good working order free from defects or wear.
I read the article on tree dangers. There are many threats to home that trees possess. Their roots can grow into and destroy foundations, limbs, twigs, or leaves falling off can also clog gutters. It can provide an easy pathway to the roof for animals, or if the tree is rotten or becomes unstable and falls it can cause serious damage to a house. These are just a few of the many dangers of having trees around a house.
Hard hats are my subject today! Around most construction sites, especially the construction of a house, there are multiple phases of the building of the structure that consist of overhead danger! A hard hat is necessary for the protection from the possibilities of falling objectsl
My subject is on a personal fall arrest system that is required when working at heights. Above six feet! The equipment, which is required to be inspected before use, consist of an anchor, a lanyard, connectors with snap hooks, carabineer, or Dring, and a full body harness
A material that may contain asbestos was used to seal the ductwork. Generally asbestos is not a hazard as long as it is not disturbed. However one should be aware of the possibility of its presence and discuss ones options with a qualified contractor.
Aging in place, is the ability of Individuals and there homes to adapt and become more user friendly as needed to coincide with the getting older. The goal of everyone who has owned a home for a great many years is to not have to leave it just because it has become harder to do everyday things. There are upgrades, maintenance items and improvements that can be performed or installed to allow a the occupant or occupants to remain in the home. An inspector, using knowledge of products and remolding options can evaluate and suggest things that can be done so that an elderly person does not have to leave there home. After all, if paying the mortgage is not an issue and there is a budget for improvements it is less liking a person will have to leave there home. If you worked hard for your home help your home work for you.
Ladder safety is an important thing to an inspector as a tool thats commonly used in every inspection. Checking the ladder prior to each use should be done as damage could happen in transport to a job sight. Step ladders should be checked all over especially the feet, legs, and hinges as these are the most common places that I tend to find faults when I do ladder inspections in my work areas. Take a few seconds to do a quick check before each inspection you’ll be glade you did in the end.
Guard rails and covers are safety devices used to protect holes/openings in a floor or walkway when 6 feet or over the surface below. Guard rails are to be made to withstand a 200 pound force down. Post are to be no more than 19 inches apart. The top rail should be between 39-45 inches, the mid rail should be place so there isn’t a space that is over 19 inches between top, mid, or bottom rails. Cover should be made to handle twice the weight of anything that could be atop of it. And secured so it will not shift or move unintentionally.
A limited inspection was completed of the roof of this home, due to ongoing or recent rain, the inspector could not safely traverse the roof at the time of inspection. Wet roofing material can be very dangerous to mount and traverse.
Tempered safety glass is several times stronger than standard glazing and it can withstand significantly higher temperatures. Tempered safety glass is commonly found in bathrooms and storm doors. Unlike laminated safety glass, it cannot be custom cut once it is formed. Tempered safety glass usually has a stamp at the lower corner indicating that it is approved, tempered, safety glass.
It’s not that easy to see the slippery surface on this roof, its not unusual to find the south side of the roof thawed from the sun and the apposing side still with a layer of ice that is not noticeable.
In our area we have long in between seasons therefore its always a consideration.
The three picture of the water meter was interesting and I will adopt this in my inspections as our area is mostly on meters now, except for rural.
As a gas tech as well we use gas meters much the same way.
The essay is about different types of household ladders. According to the American Ladder Institute, there are officially nine different types of ladders. Common ladders that inspectors are used: step ladder (it is a self-supporting portable ladder, non-adjustable in length, having flat steps and a hinged back), single ladder (it is a non-self-supporting portable ladder, non-adjustable in length, consisting of but one section), extension ladder (is a non-self-supporting portable ladder, which is adjustable in length) and telescoping ladder
The essay is about inspecting a ladder. Ladders should be inspected before each use. In cases where a multi-inspector firm is the user, it is advisable to have routine ladder evaluations performed by one who is knowledgeable and competent. Maintain records of such inspections.
The inspector should check the ladder for damage before each use. If a ladder is damaged, label it. Do not use it until it has been repaired or replaced.
Respirators are key piece of safety equipment that should have when performing septic, crawl space and attic inspections. The respirator regardless of type should be fitted with the appropriate filter for the environment the inspector will be working in. At minimum you should choose a N95 filter, which will filter out 95% of particulate matter.
When inspecting basements inspectors can encounter adjustable steel columns. Adjustable steel columns are used to provide structural support to beams. Adjustable steel columns can be single or multi piece assemblies with a screw on the bottom for adjustment. The inspector should verify the columns are installed as near vertical as possible with less than 1 inch lateral displacement. The column should be a minimum of 3 in diameter and painted with a rust inhibitor. The column should be mechanically connected to the floor and beam. There should be less than 3 in of exposed thread.
Although work being performed on a finished home, not all safety measures have been taken. Missing graspable hand rails on the main staircase can lead to a trip or fall. Checking for safety compliance is a must at all stages of a project.
Trip and fall injuries are some of the most common injuries that take place in homes and on job sites. Safety measures can be taken to limit these hazards. Proper railings should be installed on all stairways and uneven surfaces should be fixed or marked
Attached is the railing separating the kitchen from the family room in my split level home. Railings in home interior and exterior have guidelines that must be followed to keep us safe. They have minimums heights and spacing requirements between posts.
