New Intro Class September 15th, 2008
http://www.merrellinstitute.com/irinspectoryellowpagesdotcom.jpg "NOT JUST INSPECTED… INFRARED INSPECTED"TM © Merrell Institute
USE OF INFRARED (IR) CAMERA IN AN INSPECTION 7 HOUR CLASS CERTIFICATE
Infrared (thermal imaging) is an advanced non-destructive technology that allows an Infrared Certified Trained Inspector to show you things about your home that no one can show you with a conventional inspection methods. Infrared inspections can identify and document: (each property is unique and each inspection is unique) [INDENT][INDENT]
  • **electrical faults before they cause a fire.
  • **overloaded and undersized circuits. **
  • **circuit breakers in need of immediate replacement. **
  • **missing, damaged, and/or wet insulation. **
  • **heat loss in walls, ceilings, floors, windows, doors **
  • **air infiltration in walls, ceilings, floors, windows and doors. **
  • **water and moisture intrusion that could lead to mold. **
  • **possible pest infestation. **
  • **hidden roof leaks, before they cause serious damage. **
  • **air conditioner compressor leaks. **
  • **under fastening and/or missing framing members. **
  • **structural defects. **
  • **broken seals in double pane windows. **
  • **energy loss and efficiency. **
  • **dangerous flue leaks. **
  • **damaged and/or malfunctioning radiant heating systems. **
  • **unknown plumbing leaks. **
  • overheated equipment
[/INDENT][/INDENT]**USE OF INFRARED (IR) CAMERA IN A PROPERTY INSPECTION **
NYS HOME INSPECTION CE APPROVED- WE FILED APPLICATION WITH NYS AND WE APPROVED EFFECTIVE 7-8-08
[INDENT][INDENT][INDENT][INDENT][INDENT][INDENT]APPROVED BY THE FOLLOWING ORGANIZATIONS:
  • **NORTH AMERICAN ASSOCIATION NETWORK **
  • InterNACHI CONTINUING EDUCATION CREDIT
  • HOUSING INSPECTION FOUNDATION
  • ASSOCIATION OF CONSTRUCTION INSPECTORS
  • ENVIRONMENTAL ASSESSMENT ASSOCIATION
THIS SEMINAR INCLUDES THE FOLLOWING TOPICAL AREAS:
  1. THE PURPOSE AND USE OF AN IR CAMERA IN A HOME INSPECTION
  2. EXTERIOR INSPECTING AND HE USE OF AN IR CAMERA
  3. INTERIOR INSPECTING AND THE USE OF AN IR CAMERA
  4. LIMITATIONS OF AN IR CAMERA IN THE INSPECTION PROCESS
  5. ALTERNATIVE EQUIPMENT TO THE IR CAMERA
  6. USE OF TECHNOLOGY WITHIN THE SCOPE OF WORK PERMITTED IN NYS
[/INDENT][/INDENT][/INDENT][/INDENT][/INDENT][/INDENT]New Date: !!! September** 15th, 2008 from 8am to 4pm $ 185.00 Advanced Registration**
7 hour credit-NYS, Dept. of State, Division of Licensing Services Home Inspection Continuing Education Approved
Many Schools offer IR classes for upwards of 800-1200. We are hosting this 1 day IR Seminar (7 hours) for 195.00. You do not need to own or bring a camera with you to enroll in this class. This class is viable for the Home Inspectors who wants to learn the basic uses of an Infrared Thermal Imaging Camera. We will demonstrate an inexpensive, yet quite reliable unit during the class, which retails for $ 2,995. Our other Camera, costing 7,500 will also be demonstrated. We even upgraded a less expensive camera with new software. Our program is great!** **Location: Merrell Institute Facility, 1461-16 Lakeland Avenue, Bohemia, NY 11716** **Certificate Issued by: Bill Merrell, Ph.D.- School Director, Appraisal Education Network School 631-563-7720** **Limited Seating: 185.00 Advanced Registration/Pre-Paid (Non-Refundable) 275.00 At Door Registration/Payment (if space exists)** **Name___________________________________________________________________ Phone____________________________** **Address___________________________________________________________________________________________________** ** Advanced Registration ] 185 ] At Door $ 275.00 ] Check/Money Order ] Visa/MasterCard
Credit Card #______________________________________________________ Exp. Date______ 3 Digit Code_______
Signed__________________________________________________________________ Dated____________________________
"NOT JUST INSPECTED… INFRARED INSPECTED"TM © Merrell Institute **All Graduates will be listed in the www.IRInspectorYellowpages.com Directory- A $ 150 Value…Free! **
** http://www.merrellinstitute.com/index.5.jpg**
