wchris1
(W. Michael Chris)
March 11, 2008, 3:20am
#22
John, thanks for starting this post . . . good thoughts and comments from all.
bkelly2
(Brian Kelly, AZ Cert. # 60234)
March 12, 2008, 5:35am
#23
Tub valve plumbed backwards today. How does that tip work again?
C means Caliente, right?
jmckee
(James McKee)
March 12, 2008, 1:45pm
#24
Brian
** if that is a cartridge style faucet they should be able to remove the handle at the set screw, rotate the cartridge 180 deg, and re-attach the handle …generally a simple 2 minute fix…jim**
belliott
(Bob Elliott, 450.0002662)
March 12, 2008, 1:54pm
#25
I think he was joking James.
grab a coffee:)
jmckee
(James McKee)
March 12, 2008, 2:57pm
#26
Aahhh…well I’m not that bright in the morning…come to think of it…never mind…
jgilleland
(Jack L. Gilleland)
March 12, 2008, 7:46pm
#27
I thought “C ” meant “Cold one after work”.
Oh well.
rmaday
(Rick Maday)
March 12, 2008, 7:54pm
#28
jmckenna1:
If you read it again, it does not say to turn ON a valve. It says turn OFF the
valve to the water heater (long enough for the test).
If it is already ON, why would it hurt to turn it off for this simple test.? Your not
going to flood anything by turning it off.
Then who turns it back on?
