not copper piping
Originally Posted By: hugh macginnis
We are building a house and I went to it and noticed there is no copper piping, It is all this clear plastic line. The connectors are all red and blue, which I guess would be hot and cold. what is this and is it better than copper? icon_question.gif
Originally Posted By: jpope
Pex. . .
It's told to be the next best thing to sliced bread. Very common in new construction. Stronger and lighter than copper (less expensive as well).
It hasn't stood the "test of time" as it's relatively new. More will be revealed. . .
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
copper was in the contract and they cant change anything unless it is for the better. copper is proven so do you think this change is for the better?
Originally Posted By: bkelly2
PEX has a good history so far but far be it for me to talk someone out of a copper system. Perhaps the following link will help.
http://www.ppfahome.org/pex/faqpex.html
My house is polybutylene and if we re plumb it will probably be PEX.
BK
Originally Posted By: rmyers1
The material as you describe, sounds like what is known as CPVC, or PEX
Many local municipalities have not approved the material for use.
It actually takes longer to install because of the time involved in proper support of the material. It can also be very noisey.
Material cost is much cheaper than copper.
Most Contractors still prefer to install copper.
If your contract calls for copper, you may consider discussing the matter with your local Building Inspector
Originally Posted By: ccrooker
Hugh, please let us know how you make out with the building inspector and your builder, make sure that the installer has adequate support for the lines and is installed correctly. icon_smile.gif Chuck Crooker
Originally Posted By: away
I just attended some training that included plumbing and mechanical. One half of the class was classroom and the other half was actual field inspections at new home construction sites.
The only thing being used in both the subdivisions we visited was the PEX. The plumber who did the lecture portion told the class that while it is relatively new, it has been used extensively for radiant heat systems in the past.
He is in his late 40's and "grew up" on copper. He was very suspicious of it at first and decided to do some ad hoc testing on his own before he started installing it.
He cut sections, filled them with water and then plugged the ends. Then he subjected them to freeze, thaw, and heat cycles over the course of a few months. He said his freezer is set at around 10 degrees and for heating he would place the sections in near-boiling water.
During these cycles he would alternately smack the sections with a hammer, stomp them and even drove over them with his truck (I am assuming he meant when frozen) and they never leaked or ruptured.
And yes, this is all very unscientific and only based on his word. As for what happens 20 or 30 years down the line, who knows.
One benefit that all the builders love about it is that they can have the plumber come out on Monday and on Tuesday it will still be there. Unlike copper, there isn't really a scrap market for it.
Andrew Way
Keystone Residential Inspection Services PLLC
817.441.9598
www.keystoneinspections.com
Originally Posted By: wdecker
Maybe I am just an old traditionalist, but I vote for copper.
To have the same track record, PEX would have to last >100 years with no problems.
I think that your builder is just trying to pul;l a fast one and sabve money. If he claims that PEX is better for you, either make him puty in it writing (a bonded guarantee for 50 years on the plumbing) or have him lower his prices to you by the difference between the two costs.
He claims its better and can probably produce anecdotal evidence, but is he willing to put his money where his mouth is?
Will Decker
Decker Home Services
Skokie, IL 60076
wjd@DeckerHomeServices.com
Originally Posted By: jwilliams4
Good answer, Will, good answer.
“not just an inspection, but an education”
Jae;
Us traditionalists have to stick together, eh. ![aiwebs_027.gif](upload://kYPlxwJf6Sa7c6usgGMx8DqFYvV.gif)
Will Decker
Skokie, IL 60076
Originally Posted By: bgentry
I agree with Will about having the builder put something in writing, and I would go one step further and have the price difference reflected in the price you pay at closing. The only reason I have this opinion in this case only is that you already had copper in the contract.
I built a home last year that is fairly long from end to end and the noise that our copper pipes produce gets old after awhile, so if I had it to over again it would be PEX. It would also make it easier to plum my basement.
Bradley S. Gentry
Superior Home Inspection, LLC
Harrisonburg, Charlottesville, &
Elkton, VA
www.superiorllc.net
thanks everyone I am going to discuss this with the building inspector and builder early next week.
I will let you know how I made out.
I have heard that to get the fittings for the pex latter you have to be a plumber, so making added lines is very hard to do?? icon_sad.gif
