Can anybody point me to the table that specifies how many fasteners are required connecting roof rafters to ridge board. I’ve looked through R802, but can’t find it. I see the table for rafters to ceiling joists, but not rafters to ridge.
The only thing I see is R802.3 Framing Details: Rafters shall be framed to ridge board … with a gusset plate…
But I’ve seen plenty of conventional framed / stick-built roofs that don’t use gusset plates.
What am I missing?
Background: Today’s inspection had only 4 nails connecting 2x12 rafters to ridge, which doesn’t appear to be enough nails.
Disclaimer: Yes-I know we don’t do code inspections, but I would like to have the code reference for this issue.
I inspected a home where the builder was using YP for framing…had the required nails but because yellow pine splits so bad, it was useless. I know some builders like to use it for floor systems because they can get a better price plus it spans slightly better than spruce but its nothing but junk.
I was a carpenter for 25 years in CA and CO. Standard was 3 face nails, and for the toenailed side, 3 toenails in one side of the rafter and 2 in the other. I never heard that this was regulated by code, but more of an industry accepted standard.
Kenton is mostly always right on. If the ridge is structural the rafters should be tied with hangers. Doesn’t sound like a structural ridge though (he did call it a ridge board). A ridge board is only there to provide something to nail to. The opposing rafters support themselves.
That is correct David, and the reason for 3 nails on one side and two on the other is so that the nails are not lined up on opposing sides to split the wood.
It was like that 40 years ago and should still be like that today, when attachments are done in the conventional ways of framing.
Same thing was done when I used to frame with 2"x6" studs, 3 on one side and two on the other.
Brings back old memories.
Now they use air nailers and you will have twice the amount of nails required because it is too easy to pull the trigger. :mrgreen:
That is the way I was taught too. Too bad I seldom see it anymore, but I do see a lot of roof stuctures blown off. I wonder if there is a connection, Hmmmmm](*,) Sad but true.
