The code for ventilation would not change in the event of a “power vent” for during the three years of no utilities supplied to the house during its foreclosure period, the attic will still need venting.
Check your code references, again. I think you are missing the need for a vapor barrier. Remember, attic venting is ALL about removing moisture.
Thanks James, I didn’t think about it from an angle of the power being out. In terms of the vapor barrier, I guess I need further educated on that because I’m not following you there. Doesn’t the tar paper on the shingles serve as the vapor barrier?
