The 1" holes were usually cellulose, Bill. UFFI went in through larger, usually 3" or larger holes. If they did use 1" holes for foam in your area, folks got ripped off worse than usual.
Right on!!! Putting more holes in a house loosens it up and allows more air flow from the interior into/through attics/walls.
This phenomenon will usually only happen with any severity in very damp/wet homes. In others, there may be bit of condensation which will quickly dry up when conditions change, some times within hours so it is never noticed.
:oops: :oops: :roll: :roll: Well, thank-you, Barry!! It’s good to be in the company of people with a passion for the industry. Now, if…nah…won’t say it!!
I have seen larger holes for cellulose less than 3" and even smaller (1/2’ to 1") for UFFI. Cellulose is dense and takes larger opening to prevent clogging whereas UFFI was a foam.
