What I see will be no problem but if that is an underground water line then the connection will be required to be somewhere within the first five feet of water pipe that enters the building.
If this is within the first five feet of water pipe that enters the building and the conductor is the correct size then there would be no problem with the installation.
If there is no metal underground metal water pipe and the conductor is just bonding the interior pipes then the installation would again be alright even if it is not within the first five feet of entry.
If the service is 175 amps or smaller then the #6 bare conductor is of the proper size.
