Originally Posted By: jane molina This post was automatically imported from our archived forum.
I have a kitchen wand[sprayer] that the pressure is so bad in it i don’t even use it anymore to wash my plates down. I have bought 3 new ons because I thought they were bad. still the same. I took them apart and cleaned them part by part , nothing.my house pressure is 60psi with copper lines. can someone please give me more ideas I really want this to work. pressure
throughout the house is fine just the kitchen is alittle weak
Originally Posted By: psabados This post was automatically imported from our archived forum.
Jane
Do you have a shut-off valve(s) under the sink? You could have an obstruction at the valve or it could be just defective. You may want to consider changing out the valves.
Originally Posted By: Richard A Baxter This post was automatically imported from our archived forum.
When you say kit wand sprayer are you talking about the pull out sprayer? Is the water comming out of the spout ok? If the water is coming out of the spout ok and not the sprayer head it is the diverter causing the problem if this is the case let us know what brand faucet and can tell you were it is in the faucet to replace or clean.
– Without plumbers the world would have more crap to deal with.
Originally Posted By: tvargas This post was automatically imported from our archived forum.
I Changed the diverter and it made it sprays well now but the hose that
is connected to the sink itself underneath is vibrating now when I just turn on the water from the faucet and the pressure goes high and low inintermittently
this is the spray wand hose itself. My lines are copper.
It is still your diverter what you are explainning is classic diverter problem.It is engaging and disengaging rapidly causing your problem.take out and clean if it is a new one.As much problems as you are having with it you seem to be getting alot of debris in you system.
Originally Posted By: psisler This post was automatically imported from our archived forum.
Hi Jane,
I had a similar problem with a Delta type set up. I took the assembly out and took it apart and it was corroded and clogged at the base of the assembly where the hose for the sprayer hooks into the base. I was about ready to buy a new assembly until a plumber friend said to check this out. Hope it helps.
