Originally Posted By: rcooke This post was automatically imported from our archived forum.
gbell wrote:
IRC 2003 Definitions
DWV. Abbreviated term for drain, waste and vent piping as used in common plumbing practice.
Roy
Steve has more credentials than most of us will ever have. We all try to be like Steve.
I did a 14 year old home last year and it still had the orange test cap on the vent pipe on the roof . The owner said every thing seemed to work well for him . That was a first for me . I did not take it off .
Roy Cooke
Originally Posted By: tgardner This post was automatically imported from our archived forum.
I did an inspection of a roughin the a while back and found that the plumber had Super-glued the Pressure guage mechanism at 10 PSIG. I figured this out when I tripped in the gravel and while falling, pulled apart a stub out trying to catch myself. The pipe came off in my hands, and the guage still read 10 PSIG!
Originally Posted By: gbell This post was automatically imported from our archived forum.
DWV systems shall be tested on completion of the rough piping installation by water or air with no evidence of leakage. Either test shall be applied to the drainage system in its entirety or in sections after rough plumbing has been installed, as follows:
1. Water test. Each section shall be filled with water to a point not less than 10 feet (3048 mm) above the highest fitting connection in that section, or to the highest point in the completed system. Water shall be held in the section under test for a period of 15 minutes. The system shall prove leak free by visual inspection.
2. Air test. The portion under test shall be maintained at a gauge pressure of 5 pounds per square inch (psi) (34kPa) 0r 10 inches of mercury column (2488 Pa). This pressure shall be held without introduction of additional air for a period of 15 minutes.
When I am wearing my building inspector’s hat and observing a gas or DWV pressure test, I always have the plumber let out air and watch the gage drop at the end.
– Robert O’Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Hi to all
Rob I hope that you are not suggesting that some inscrupulous contractor might have a guage stuck at 5psi, that would be real hard to believe
Naw, that would never happen Gerry …
I haven't run across any fused gages (yet) like Tim did, but I have had one where a valve right after the gage was shut off for the system pressure test. After opening the valve the gas piping leaked like a used blow up doll on a nail bed ...
He swore up and down he didn't have time to trace the leaks before I got there, and was gonna fix it before the meter was set. He got the hint that wasn't a good call after three red tags and charges for the additional inspections ...
-- Robert O'Connor, PE
Eagle Engineering ?
Originally Posted By: bking This post was automatically imported from our archived forum.
I’ve seen a stuck needle on a pressure gauge on a hydraulic system, the kind that has a liquid immersed needle and no reason to be tampered with. It was stuck at the usual pressure that was present for several years.
