Originally Posted By: lschmid This post was automatically imported from our archived forum.
Dave, thanks for the daily questions. They are a good stimulus to get us thinking. I like the variety too. I know it takes time each day. Thanks. Another good example of NACHI working the way it is meant to be. Helping others to help others.
Originally Posted By: tgardner This post was automatically imported from our archived forum.
Dave,
I voted, but the really none of the answers by themselves are complete. I won't give away what I answered was the best of the answers here so I'll wait till tomorrow to comment further.
Dave,
It's now Sat morning.
The popular answer, "leave a one inch space " is too general. I think the proper answer is a combination of soffit vents with eave baffles, a minimum of 1" between the insulation and the roof sheathing, and ridge vents at the peak of the rise ( sometimes tricky on shed type roofs).
Originally Posted By: lwilliams This post was automatically imported from our archived forum.
Of course the definitive answer is, as a home inspector without a cross section of the home inspected, you can’t see if the area has been properly insulated. Keep up the great work Dave, I look forward to your questions everyday.
Originally Posted By: dbush This post was automatically imported from our archived forum.
The correct answer is 1" of space.
Now, I understand that some of the other answers are close, but just like on the NHIE, and several state exams, these questions are written in a manner that there may be some answers that appear correct, but one is either more correct than others, or one is definitely correct and the others are not.
I do understand that some extinuating circumstances, such as cedar, may change things a little, these are directed more toward normal circumstances, which would be considered drywall.
Originally Posted By: Blaine Wiley This post was automatically imported from our archived forum.
Thanks for stating that so eloquently, Erby. I chose the 1" answer because I Interpreted the question to mean 1" between the insulation and the sheathing. Your answer may show why many others chose the “wrong” answers.
I don't remember the wording on the NHIE being that ambiguous, but I still enjoy this thread. Keep it up, Dave!
Originally Posted By: Guest This post was automatically imported from our archived forum.
Actually, the fill the cavity answer is just as correct. It’s an effective and correct way to address cathedral ceilings by filling the cavity w/ expanding foams using no venting system and for cold climates may actually be preferable. Using fiberglass batts or blown in, or cellulose fill, an inch gap between the sheathing and the insulation (not around it) WITH eave to ridge venting is an acceptable method. An inch and a half is better, encouraging better convective action and less radiant transfer of heat that made it through the insulation.
I wasn’t trying to be a smart aleck. Just posted it as a point of reference to further illuminate the issue. I wouldn’t want to see anyone writing a foam filled cavity as necessarily being an issue. Even after the stuff I wrote there are other factors like vapor barrier, cavity depth etc. that must be considered to determine the best approach.
Originally Posted By: jfarsetta This post was automatically imported from our archived forum.
Wasn’t meant to call you a smart alec! These questions reveal that there’s sometimes more than one acceptable answer, if you analyze them. Your post was good, and helps other members look at things differently. Of course, most is moot, as the cathedral ceiling is finished, and there’s not much we can see.
A few years back, builders crammed insulation into these cavities. Now, ther's the source of many a problem!
-- Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
