Welcome To Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified .
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books "Now That You’ve Had A Home Inspection"
** Seventeen Custom Branded Videos value $50.00 ~ your choice!
https://certifiedmasterinspector.org/video-contest 1
GOOD LUCK!
For all those who do pool and spa inspections…and everyone else…
- An above ground pool should be level within.
a) 1/2 inch
b) 1 inch
c) 6 inches
d) 1 foot
2)The highest concentration of contamination is located at the _______________ of the pool
a) bottom
b) surface
c) walls
3)_______piping and fittings are commonly used for residential swimming pools.
a) ABS
b) Copper
c) PEX
d) PVC
- It is recommended that the water temperature for a pool be set between 78*F and____*F, and spas should be no hotter then ______*F.
a) 65…82
b) 82…104
c) 82…120
d) 95…104
5) To avoid problems with water quality, pH must be maintained between 7.2 and 7.8.
True
False
6) Most everywhere in the world, spas are maxed out at ___ degrees since ___.
Higher temps can cause ___.
a) 120, 1985, heart attack
b) 98.6, 2000, skin rash
c) 104, 1980, heat stroke
d) 212, 1975, 3rd degree burns
