Welcome To Questions of The Week!
A member of the Awards Committee will post questions, at a random day/time.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submit your Mailing address for shipping.
Choose your prize from the following list!:
** $50.00 gift certificate from Inspector Outlet
** Case of books "Now That You’ve Had A Home Inspection"
** Seventeen Custom Branded Videos value $50.00 ~ your choice!
https://certifiedmasterinspector.org/video-contest
**MOST members are eligible… … …
The projecting course of stone or brick masonry at ground floor level is called
(a) DPC
(b) plinth
(c) lintel
(d) jamb -
In Ashlar fine masonry
(a) height of stones used is never less than their breadth
(b) length of stones is never less than twice their height
(c) both (a) and (b)
(d) neither (a) nor (b) -
Fire resistance of stone masonry is
(a) very low
(b) low
(c) moderate
(d) very high -
An impervious course laid at plinth level to prevent rise of water from foundations to superstructure by capillary action is called
(a) DPC
(b) plinth course
(c) jamb
(d) sill -
Choose the incorrect statement.
(a) In rubble masonry the stones received from a query are used without dressing.
(b) uncoursed masonry is the cheapest and weak type of masonry
(c) random rubble masonry is used for low-cost housing.
(d) coursed rubble masonry is an inferior type of masonry -
(a) stones are dressed true and square on all sides
(b) height of course never less than 30 cm
(c) the thickness of joints should not exceed 3 mm
(d) all the above
