ksilvas
(Keith Silvas)
November 24, 2025, 5:54pm
does anyone have any idea what’s going on with this wall furnace? This was on a coastal San Diego condo. The exterior temperature was approximately 60°, not very cold. The rattling started after the furnace had been running for about 20 minutes and continued after shutting it down. First time coming across something like this.
Video: Rattling Furnace
ksilvas
(Keith Silvas)
November 24, 2025, 6:20pm
3
No sir, just a light on shore breeze
lkage
(Larry Kage, CMI)
November 24, 2025, 6:53pm
4
Well, huh, whatever qualified professional you referred it out to will figure it out, eh?
jjonas
(Jeffrey Jonas)
November 24, 2025, 6:58pm
6
Did you check for Recalls.
These wall heaters have a long history of issues, and many have recalls associated with them.
kleonard
(Kevin Leonard, CPI/CMI)
November 24, 2025, 7:13pm
7
Did you check the oil?
Sounds like it’s got a knocking rod.
mfellman
(Matt Fellman)
November 24, 2025, 10:15pm
8
Calling that a “rattle” is quite generous…. sounds like gun shots.
Probably the blower fan has something caught in it or has failed bearings and is flopping around.
ahowell1
(Adam Howell, CPI)
November 24, 2025, 10:26pm
9
Did the furnace have a blower?
ruecker
(Ryan Uecker)
November 24, 2025, 10:53pm
10
Someone, or something, is trying to get out of that thing.
jspencer
(Jeff Spencer)
November 24, 2025, 10:59pm
11
bcawhern1:
I think you broke it.
The seller agrees. They have never heard it.
escanlan
(Emmanuel Scanlan, TREC# 7593)
November 24, 2025, 11:19pm
12
Keith Silvas:
The seller stashed the kiddies in the unit so they would not get in your way. Apparently they did not realize you would be testing the system. Probably the little kiddies in there whirling around.
ryoung7
(ROBERT YOUNG, CMI)
13
Just an opinion but, a damaged heat exchanger can produce rattling or popping noises as the crack in a heat exchanger expands and contracts with temperature changes.
That’s my wag.
jspencer
(Jeff Spencer)
November 24, 2025, 11:25pm
14
Total guess, but it sounds almost like a continuous backfire. Something in gas valve could be causing it.
lmorrison
(Larry Morrison, CMI)
November 25, 2025, 6:39pm
15
Farewell and adieu to you fair Spanish ladies…. Recommend a Bigger Boat… https://youtu.be/hSbbc06EW9g?si=TVCAlNO1AMb2SkXW&t=32
lhenderson2
(Lon Henderson, CMI®)
November 26, 2025, 12:21am
17
Damn gremlins get stuck and raise hell trying to get out.
It could be several things, but obviously, report the noise for repair by a HVAC tech. Try to talk to the tech after it is fixed (or maybe replaced).
dandersen
(David Andersen, TN HI# 40)
November 26, 2025, 3:36pm
18
Fan. Open it up and look next time.
jjonas
(Jeffrey Jonas)
November 26, 2025, 3:41pm
19
Curious…
Did you bother checking for a Recall, (Manufacturer unknown to us on the MB), or did you just blow off my comment like many here do??
Hopefully your clients don’t die from…
dandersen
November 26, 2025, 3:44pm
20
Maybe you need all caps in Bold 2" font!
