Here are a few photos on a current structural engineering project I am working on.
It’s a 1950s commercial block building 100’x50’ with a flat roof. It has a block wall down the center creating a series of 20’ x 25’ bays. Every 20’ has a W16x36 steel beam with 20’ 2x10 at 16" centers. The aerial photo from Google clearly shows the bays with water stains in each bay due to previous ponding. The last bay in the top right corner has standing water when the photo was taken. The roof rafters recently broke and caved in about 18 inches. For now it was temporarily shored up until repairs can be made. The roof failure was due to several factors:
- Being flat the roof has no positive drainage other than running off the back wall.
- The natural sag (deflection) of the 2x10 joist due to the dead weight of the roof creates a a low area for water to pond. This was a EPDM roof with 1" ballast rock on top.
- Wood will experience additional long term deflection 1.5 to 2 times the initial deflection called creep. Creep is basically the stretching and/or compression of the wood fibers over time, which is permanent.
- The roof joists were #2 grade lumber.
Over time the initial deflection allowed water to pond creating more sag until one or more rafters cracked at large knots in the joists. When a joist breaks its load is transferred to the adjacent joist, which fails and you see the picture.
Turns out the #2 2x10 joist at 16" centers were doomed to fail from day one. The weight of the dead load combined with the snow load would exceed the allowable bending stress of the joists by 21 percent. The repair is to install new 2x10 Select Structural Grade joists at 12" centers as a temporary repair for the damage. The remaining bays constructed the same are now in question. Modern building codes don’t allow flat roofs. Two percent is now the minimum for a low-slope roof. I am meeting with the owner and the city building code official to see where we go from here.
As commercial inspectors don’t assume a flat roof with evidence of ponding that hasn’t failed in the last 70 years can’t fail tomorrow. Make note of any signs of ponding, including clogged drains on sloped roofs that also create potential ponding failure.
